Generate a drilling plan
To generate a drilling plan, I use the Files/Manufacturing files/drilling files/Plan file format .pdf menu.
This utility actually generates a plan but does not respect the scale of the printed circuit.
My question is how to generate a scale 1 drilling plan?
How far off is the scale? Are you printing the pdf to paper? If so, are you sure that it’s not your pdf viewer that changes the size in order to fit the entire print on the paper?
Perhaps you’ve read this post
Also, you can use FreeCad with StepUp (KSU) to load a PCB, then Dimension it in FreeCAD’s TechDraw Workbench to create a professional drawing… quick example below
Check out ‘plot’ instead of print.
Don’t use printer. Use plotter. Check for plot function in your software ribbon bar
