Hello there,
So I’m using this BQ76PL536A foot print that was available in one of the kicad libraries and when I switch to 3D viewer the solder mask doesn’t seem to appear…
is it just a bug in the viewer or an actual problem? this board needs to go to manufacturing.
even oshpark’s GERB view doesn’t manage to see it what is going on?
bobc
August 9, 2017, 9:43pm
3
It’s probably an error in the footprint. BQ76PL536A doesn’t appear to be in the official libraries.
Where did you get it?
Sorry it’s here:
Housings_QFP:TQFP-64_1EP_10x10mm_Pitch0.5mm
bobc
August 9, 2017, 9:49pm
5
The version I have looks like this
What are you expecting?
The foot print’s pads manage to appear like that for me.
bobc
August 9, 2017, 9:57pm
8
I’m stumped! Clearly that footprint is unusable. How does it look in the footprint editor? Maybe some soldermask settings have got messed up.
For now I just need a quick fix should I just download the lib from github and replace the file?
bobc
August 9, 2017, 10:04pm
11
You could try that, the github version doesn’t seem to have changed significantly for some time.
What is on the “Local Clearance and Settings” tab for the pad?
Sounds like you may have hit this feature:
Hi All
I am designing my first board with Kicad. It is 4 layers with components on both sides. I have just made the Gerbers and found that all of the SMD components on the back of the board and two on the front do not have a solder mask defined and hence could not be soldered.
I think this may have been caused by me having the b.mask layer switched off when I designed the board. I had to turn this on when i made the Gerber plots. The components affected are all from the standard libraries.…
bobc
August 9, 2017, 10:18pm
13
The footprint looks ok, but I would try reloading it into the PCB.
The footprint is indeed defect.
It has clearance settings in the footprint settings enabled.
(-1.8mm)
Fix commited:
KiCad:master ← poeschlr:fix_tqfp_64_ep1
opened 10:30PM - 09 Aug 17 UTC
Fix is merged with the library.
@Mike_Lemon
If you use online libs simply update the footprint on your board.
press e when above the footprint (opens footprint properties dialog)
press the change footprint button (opens change footprint dialog)
select change footprint of 'reference' or change footprint of 'footprint'
press apply
If you use local libs you need to update your libs. (Re run the library wizard to do so.)
Yes it did it thank you very much!! how did you even find that github topic thing?
I created the pull request i linked because of your report here. (So it was new when i linked it.)
You said someone managed to fix it in a few minutes? nice! also is there an effective way to update footprints globally in a pcb?
In the change footprint dialog there is a selection for all footprints. This reads all footprints from the lib.
Only one setting needed fixing. When i saw your post i first checked if the problem is with the footprint or somewhere else.
After finding the footprint is at fault i forked the repo and fixed the footprint in my fork.
Created a new pull request which was merged within a few minutes by one of our library managers. (I’m not allowed to merge my own pull requests)
Another manager found another problem with most of the footprints in this lib. (Wrong naming convention. The “_” before 1EP should be “-”)
