I would like to create a footprint not only on front and back copper but also in inner layers. Is this possible?
I’ve tried to use some tricks but no result.
This footprint is just a trace drawing that I would like to make an array of it in PCBnew.
HI,
you can create a module e.g. with your path in FrontSilk
export your module and open it in text editor
change the layer from F.SilkS e.g. In1.Cu
that should let you have your module as request…
The trick can be done also with Bitmap2Component app
Maurice
I’m trying to make a footprint that has 3 pads. One pad in Inner1.Cu and two on B.Cu. So I assign the pad that should be in Inner1.Cu as a pad on F.Cu. Then I’ve made some changes as Maurice suggested but couldn’t make the pad of Inner1.Cu to be visible. It is visible only in 3D-view. Do you have any advise on this problem I am facing?
Thank you maui for your reply. It solved my problem but in PCBnew I see the pad that you assigned in Inner1 in grey color an not in the color that Inner 1 is. In 3Dview and GerberView everything is fine.
that solution is a workaround for something not implemented in kicad …
to have a different color representation you will need to change the source code…
but I would stay like that
Laying out a spiral coil on four layers and used a tool, spiki, that generates the track as a footprint.
Easy to modify the kicad_mod file with the inner layer. There’s no apparent way to move a footprint to an inner layer via the gui so this looks like the only solution right now.
It’s even easier if using a Plugin (once getting over the Hurdle of making a Simple Plugin. Look into “Simple Plugins” for Kicad… and check out some examples… 3 lines of code.
Example below moves the Selected Tracks to the Inner Copper Layer #1 (In1_Cu)
