Hello Everyone,
Name is Robert and I am a new KiCad user and fairly new to electronics design. My current designs have stemmed from a direct need of a solution, ‘I need to research what components will work to solve this issue or accomplish this goal’ as opposed to ‘I want to learn electronics’. I have worked with bread boarding, done basic projects and have a basic understanding of all the major components and their functions as well as the basics of voltage, amperage, and impedance. I also have basic understanding of programming and have programmed several micro controllers to do basic tasks.
I am also an automotive technician, specializing in restoration, retro-mods, road racing, engine building and performance and occasionally general repair with 30+ years of experience. I am not looking to become an electrical engineer, but I do need to know how to create custom solutions when the need arises. I typically don’t have tinker time and have to lean on the community for help with getting me pointed in the right direction in finding a solution. My apology if that intro was a bit lengthy.
Ok, so my first project is…a simple controller to trigger the negative side of a relay coil that triggers a relay which in turn controls a cold start valve on a diesel engine injection pump. I am using an buck converter from Adafruit based on the MPM3610 chipset to regulate voltage from system 12v to 5v to power up the OPA347 single OpAmp set-up in a voltage comparison circuit as well as power up our voltage divider circuit for the comparison. I am using a 680/220 ohm split to pull down the 5v to 1.23v. The CTS (coolant temp sensor) is high (up to 3.3v) when cold and the voltage drops lower as the temperature goes up. In this case, 60C (140F) is the 1.23v mark, as long as the voltage is above the 1.23 mark the OpAmp will output a 5v signal which drives a IRLZ44N Mosfet. This is turn drives the ground side of the drive coil for the power solenoid that powers up the relay that in turn powers the cold start solenoid of the injection pump. Once the voltage signal on the CTS reference line drops below 1.23v, the OpAmp shuts off the 5v drive output to the gate circuit of the Mosfet and is pulled to ground via a 10k resistor.
So I have already spent a few hours on the schematic editor building a schematic, it looks clean and readable to me, but perhaps it can be further cleaned up. Now I have already built this and tested it on a breadboard and have put it into an enclosure. I want to use this as a learning project before moving on the larger glow plug controller which I have already built but its hand drawn schematics and very hackishly soldered on to perf board, but that is for another day.
Today I have been delving into the PCB editor and oof, I am totally unfamiliar and am pretty lost from the get go. I will dive into some videos to try to get some clarification and direction. I can see right away I am going to have to create a custom footprint for the buck converter as right now its just setup on a standard TO-220 footprint and the pins are reversed. I can temporarily fix this by flipping the part upside down to the bottom of the PCB but this is not a correct fix. In addition the OPA347 OpAmp is going to need to be custom built into the symbol library(?) as I am just using a generic DIP-8 package footprint and get pin errors when I go from schematic to pcb editor.
Any comments on the project are welcome, and I am aware this is pretty off topic in some ways but I wanted to introduce myself but did not see specific place to do that. I figured I might get some slack on my first post, hopefully the mods don’t roast me too bad here.
Thanks and I look forward to being an active member.
