Filled zone (copper area) via Python script bindings
I’m looking for documentation on how to create copper zones programmatically. I typically refer to the API docs, is that the latest and greatest?
Searching the forum I get results from back in 2015 pointing to (at the time) hacky solutions and I was hoping for something more actual.
I tried some variations of the following with no success, can you guys point me in the right direction?
fs = 10e6
sps = pcbnew.SHAPE_POLY_SET(self.board)
sps.SetVertex(fs,fs)
sps.SetVertex(-fs,fs)
sps.SetVertex(-fs,-fs)
sps.SetVertex(fs,-fs)
z = pcbnew.PCB_ZONE(self.board)
z.SetLayer(pcbnew.F_Cu)
z.SetFilledPolyList( pcbnew.F_Cu, sps)
self.board.Add(z)
cheers,
stef
I think you need to use AddPolygon() (or possibly SetOutline() ) instead of SetFilledPolyList() for defining the zone outline.
Hi @Jonathan_Haas ,
thanks for the quick reply. I’ve tried what you suggested, both methods alone and also together, passing the same SHAPE_POLY_SET as before.
Same result, nothing shows up in the layout unfortunately
I’m not sure you’re creating the SHAPE_POLY_SET correctly. I believe you have to call Append(…) to add points.
But at the moment I don’t have time to mess around with this. I can create an example this weekend maybe.
There are many different ways but I’m using AddPolygon(). To deal with differences of 5.1 and 6.0, I once create an unconnected kind of prototype zonedefaults object and use that with a copy constructor. It might have changed in 6.99 again, though…
Thank you guys,
with the input from @mgyger (awesome code snippets man!), and fixing a bug of mine, I got it to work (see below). Other approaches might work as well but I didn’t test them.
fs = 10e6
points = (
    pcbnew.wxPoint(fs,fs),
    pcbnew.wxPoint(-fs,fs),
    pcbnew.wxPoint(-fs,-fs),
    pcbnew.wxPoint(fs,-fs)
z = pcbnew.ZONE(self.board)
z.AddPolygon( pcbnew.wxPoint_Vector(points) )
z.SetIsFilled(True)
self.board.Add(z)
# fill board
filler = pcbnew.ZONE_FILLER(self.board)
filler.Fill(self.board.Zones())
pcbnew.Refresh()
cheers
stef
