I’m trying to create a filled polygon in pcbnew 7.0.8 using the Python API, like the “Draw a graphic polygon (Ctrl+Shift+P)” tool does in the GUI.
I’ve tried variations of the suggestions at the following sources, but even after adapting as best as I can for the v7 API, I end up with zones (or can’t get it to work at all)… and never a filled polygon:
[also others… but I’m not allowed to link to more than two]
How can I turn a set of points into a filled polygon in pcbnew v7 using Python?
If you end up with zones that’s probably because you are creating zones. If you want a simple graphic shape then you need to create a PCB_SHAPE and pass SHAPE_T_POLY as type. Working with it later is similar to zones so if you get stuck, ask away.
I see now where I can SetFilled(), but I’m still not sure how to actually a workable PCB_SHAPE from a SHAPE_LINE_CHAIN in the first place. (For that matter, I don’t see how to get a SHAPE_T_POLY from anything, either…)
Here’s what I have:
#### DOES NOT WORK ####
import pcbnew
from pcbnew import FromMM
board = pcbnew.GetBoard()
pts = [
# in mm
(0, 0),
(10, 10),
(10, -10),
(0, 0)
pts = [(FromMM(x), FromMM(y)) for (x,y) in pts]
chain = pcbnew.SHAPE_LINE_CHAIN()
for (x,y) in pts:
chain.Append(x, y)
chain.SetClosed(True)
sps = pcbnew.SHAPE_POLY_SET()
sps.AddOutline(chain)
ps = pcbnew.PCB_SHAPE(board)
ps.SetPolyShape(sps)
ps.SetFilled(True)
board.Add(ps)
pcbnew.Refresh()
Right now this code just creates a single line segment of zero length at the origin.
The reference I linked has a search function, if you enter SHAPE_T_POLY in it it will bring you to the field definition, it’s directly in pcbnew module. So your constructor should look like
pcbnew.PCB_SHAPE(board, pcbnew.SHAPE_T_POLY)
everything else seems right at first glance, probably the above is the only piece you are missing.
