I’m not sure if this is the correct section for this, if not lmk what is. I’m trying to see if there is a way to export my Pcbnew design into some simulation software in order to test it.
What kind of simulation software?
I was thinking like QucsStudio or LTspice
From the schematic -> Tools->Generate Netlist
Not sure what Qucks does. NGspice is being incorporated into Kicad directly. Have you tried that?
No I haven’t tried NGspice but i’ll give it a try. Thank you
It isn’t fully implemented in Kicad yet so there are some limitations. @holger can point you in the right direction if you need help. Good luck with your project.
Sounds good. Thank you
Take a look at the official tutorial for using ngspice in KiCAD.
