This isn’t version specific at least with the last couple of versions. And it is also more about using KiCAD and the simulator for technical illustration or technical lab notes.
Sometimes I want to compare two slightly different circuit configurations or different values in the same circuit. So, I copy and paste special so the component designators do not change since they are intended to match a schematic under discussion or my own review.
Then, I ‘exclude from simulation’ one of the two almost identical circuits that I want to compare. The simulator objects and wants to re-annotate one of my circuits, but since this is more for technical illustration, or my own notes, I want to keep the same designators references.
Would it be a good idea to have ‘exclude from simulation’ to also ignore the duplicate designators ? Or does that cause some other problems also.
I hope I’ve explained that so it is understandable. Thanks.
An edit: I work around this now by selecting all of one of the two circuits, deleting the one I don’t want to simulate, do the simulation, then return to the schematic and perform the UNDO to get the deleted one back.
Works.
