I have some warnings. and can’t find reasons
here is my related circuit. I think the connection is well.
could you give me some advice?
(this connection is made by request of my team worker who is in charge of Software, so I don’t know the purpose of it , I’ve just made connection between MCU pins and Through hole for header pin)
***** Sheet /MCU/
ErrType(3): Pin connected to other pins, but not driven by any pin
@(269.24 mm, 33.02 mm): Pin 2 (Input) of component CONN1 is not driven (Net 41).
@(269.24 mm, 27.94 mm): Pin 1 (Input) of component CONN1 is not driven (Net 42).
@(193.04 mm, 93.98 mm): Pin 32 (Input) of component U9 is not driven (Net 63).
@(193.04 mm, 97.79 mm): Pin 31 (Input) of component U9 is not driven (Net 64).
@(252.73 mm, 152.40 mm): Pin 2 (Passive) of component BD2 is not driven (Net 68).
but actually I’ve read it before.
these pins are not for power input or output, just signal connection. so I don’t think I should use Power Flag to solve warning.
and what do you think about this?
(I think I missed something, because I’m not good at reading English , so I had many times of misunderstanding. but if you let me know what I am misunderstanding I really appreciate it)
PS : I just solved warning, I change through hole pin 1, 2 from input to output, then warning is gone
thanks
Project specific connector symbols can reflect the function of the device connected to it off board. It is a totally legitimate usecase but requires understanding of ERC as simply changing the pin types till it stops complaining is not really the right solution.
