ErrType : Pin connected to other pins, but not driven by any pin
I have some warnings. and can’t find reasons
here is my related circuit. I think the connection is well.
could you give me some advice?
(this connection is made by request of my team worker who is in charge of Software, so I don’t know the purpose of it , I’ve just made connection between MCU pins and Through hole for header pin)
and here is ERC report
ERC report (10/05/2019 15:58:52, Encoding UTF8 )
***** Sheet /
***** Sheet /BLUETOOTH/
***** Sheet /FAN_HV_12V/
***** Sheet /DUST 5V/
***** Sheet /PW CHARGER/
***** Sheet /TOUCH, LED/
***** Sheet /MCU/
ErrType(3): Pin connected to other pins, but not driven by any pin
@(269.24 mm, 33.02 mm): Pin 2 (Input) of component CONN1 is not driven (Net 41).
@(269.24 mm, 27.94 mm): Pin 1 (Input) of component CONN1 is not driven (Net 42).
@(193.04 mm, 93.98 mm): Pin 32 (Input) of component U9 is not driven (Net 63).
@(193.04 mm, 97.79 mm): Pin 31 (Input) of component U9 is not driven (Net 64).
@(252.73 mm, 152.40 mm): Pin 2 (Passive) of component BD2 is not driven (Net 68).
** ERC messages: 5 Errors 0 Warnings 5
thanks for reading
Thanks eelik
but actually I’ve read it before.
these pins are not for power input or output, just signal connection. so I don’t think I should use Power Flag to solve warning.
and what do you think about this?
(I think I missed something, because I’m not good at reading English , so I had many times of misunderstanding. but if you let me know what I am misunderstanding I really appreciate it)
PS : I just solved warning, I change through hole pin 1, 2 from input to output, then warning is gone
thanks
What is the pin type of pins 1 and 2 of the connector?
I know you want them to be a signal, but could you edit the pin and check?
they was input type, but I modified it as output
and this is before and after below (left to right)
(and all MCU pins are input type)
You would better set all connectors pins to passive (not input or output). A connector is a passive device, not an active one.
Project specific connector symbols can reflect the function of the device connected to it off board. It is a totally legitimate usecase but requires understanding of ERC as simply changing the pin types till it stops complaining is not really the right solution.
