Error in Simulator installation
I’m getting this:
E: /var/cache/apt/archives/libngspice-kicad_0.1-42~202402021044+902a62d2f~ubuntu20.04.1_amd64.deb: trying to overwrite ‘/usr/lib/x86_64-linux-gnu/ngspice/analog.cm’, which is also in package ngspice 31.3-2
I’m on Linux Mate up-to-date 20.04 I think with a Kicad install from today.
Version: 8.0.3-8.0.3-0~ubuntu20.04.1, release build
wxWidgets 3.2.1
FreeType 2.10.1
HarfBuzz 2.6.4
FontConfig 2.13.1
Platform: Ubuntu 20.04.6 LTS, 64 bit, Little endian, wxGTK, X11, mate, x11
Date: Jun 4 2024 12:41:44
Boost: 1.71.0
OCC: 7.6.3
Curl: 7.68.0
ngspice: 42
Rgds,
Steve
Nice message, because it does not answer: is it successfull overwriting or does it stop?
You have a (5 year old) ngspice-31 installed (package ngspice 31.3-2). Unfortunately analog.cm (additional libs for ngspice) etc. are not compatible with new ngspice-42 (from KiCad). So uninstall ngspice-31 before installing KiCad.
Of course then the standard, standalone ngspice executable is missing from your setup. I do not know if ngspice-42 is available for Ubuntu 20.04.
Thanks. I had to uninstall the ngspice and the Kicad. I have re-installed. At least there are no broken packages now. I’ve never used the simulation software so I don’t know if it is working.
I think my new task will be to change everything over to Ubuntu Mate 24.04. I’m not looking forward to it !
It stops… in fact it impeaches ngspice, whatsoever version to be installed while Kicad remains installed.
The ngspice-42 already built isn’t available for Ubuntu 20.04, in fact is only available in the default package repos in Ubuntu 24.10 “Oracular Oriole”.
HTH
