When I open a V5.1.10 schematic in V5.99, I get this error message.
Can someone explain why Kicad is trying to open a zip file?
I also tried to open a different V5.99 project and I get the exact same error. With the same file path.
If I create a new project in V5.99, then save the schematic file, close the project and re-open it again, the error is not present.
I suppose there is a file path listed somewhere that I should remove, but I have no idea where and why.
Here is my current version info.
Application: KiCad Schematic Editor (64-bit)
Version: (5.99.0-11575-g46338403e7), release build
wxWidgets 3.1.5
libcurl/7.74.0-DEV Schannel zlib/1.2.11
Platform: Windows 10 (build 19041), 64-bit edition, 64 bit, Little endian, wxMSW
Date: Jul 29 2021 08:59:27
wxWidgets: 3.1.5 (wchar_t,STL containers)
Boost: 1.75.0
OCC: 7.5.0
Curl: 7.74.0-DEV
ngspice: 34
Compiler: Visual C++ 1928 without C++ ABI
KICAD_USE_OCC=ON
KICAD_SPICE=ON
