Erratic simulation
I copied the drivers sch that is available as exemple and modified it to have PWM input.
While I manage to run the simulation once, it suddenly did not wanted to work later.
And of course the error console is as usually complete non-sense
That is not the first time that happened and really frustrating. Any idea ?
H-Bridge_PWM.zip (23.1 KB)
Attached is the SCH with all needed files.
That’s wrong. See 1).
There is never a ‘suddenly’.
  1. Note: No compatibility mode selected!
The device models require compatibility set to PSPICE and LTSPICE
  1. The bridge has input nodes Vin22, Vin23.
    Your OpAms have output nodes Vin1, Vin2.
Hi Holger and thanks for your usual prompt help.
Indeed my labels where wrong. That’s the usual mistake when I play with multiple un-do.
Concerning the compatibility mode, I swear I haven’t changed anything. The model was running, then I had this error and perhaps I changed smg in order to make it running.
Nevermind it’s now working. Not from the electronic point of view but that’s another story. (It was running also from a physics perspective before, yes yes!)
