Date: May 31 2023 23:56:22
Boost: 1.74.0
OCC: 7.5.2
Curl: 7.88.1
ngspice: 38
Compiler: GCC 11.3.0 with C++ ABI 1016
KICAD_SPICE=ON
I brought up an old circuit for simulation purposes, and the simulation won’t run with the errors:
Errors during netlist generation. simulation aborted
Error reading simulation model for B2
Failed to read simulation model from fields
Error reading simulation model from symbol B1
When I ran ERC, I get a lot of warning about The current configuration does not include the library ‘pspice’.
How do I install pspice on Ubuntu 22.04 and how do I clear out the simulation errors. The circuit did simulate under KiCad 6.x
Very likely that you have a problem.
Some libraries have new names in 7.0, and “pspice” is one of them.
It’s now called “Simulation_SPICE”.
You’ll need to update your old projects (hint: this does not happen when you use personal libraries. Check the FAQs).
When I try to simulate the circuit, I get an error message and KiCad crashes (closes)
Unhandled exception class: St12out_of_reange what: vector::_M_range_check:__n(which is 0) >= this->size() (which is 0)
I have added 2 zip files. #4 was my starting point and has the original errors in ERC and simulations. In #5 I removed B1 and B2, added pspice to my system, and that is the one that crashes. MOSFET-test4.zip (253.7 KB) MOSFET-test5.zip (322.1 KB)
If I am messing something from the zip file, please let me know. I really appreciate you looking into this.
The problem is not the PSPICE simulation library. ERC doesn’t give a hoot about simulation.
The problem is that the symbol library “spice” has a new name (*).
You need to update each relevant circuit symbol in the “Properties” window. There are some import/update options available, but for a small(ish) circuit I find it quicker and easier to just delete the existing symbol and reload it from the new library.
(*) actually it doesn’t, it’s just no longer there. 6.0 had both “pspice” and “Simulation_SPICE” as symbol libraries. 7.0 has only “Simulation_SPICE”.
