Continuing the discussion from Elektuur Style Symbol Library.
Oktizer
Oktizer
is an Action Plugin to create octagonal looking pads and vias in the PCB Editor. It works somewhat similar to how KiCad 6.99 is currently doing teardrops but it also modifies pads.
Currently, there is no GUI (edit the python file to change corner rounding [radius 0.05 mm ≈ 2 mil] or chamfer ratios [29.29% and 20.71%]) and it needs to be copied to the plugins
folder of KiCad 5.1
or KiCad 6.0
(it doesn’t need its own folder, though), or it can be installed using PCM on KiCad 6.0
. Thermal reliefs may not work correctly with the generated custom pads and may need explicit tracks (for KiCad 6
, chamfered rectangles could be enabled instead by uncommenting some code).
Before running it, the PCB needs to be prepared first with either:
- Tools → Cleanup Tracks & Vias… → ☒ Merge co-linear tracks
- Edit → Cleanup Tracks and Vias… → ☒ Merge overlapping segments
and after selecting the desired pads and vias (or else it modifies all round/circular/oval/rectangular/square PTH pads and vias):
- Tools → External Plugins… → Oktizer
or use its tool button. Undo/Redo should work. If only board graphics shapes are selected, the circles and rectangles/squares are changed to (filled) octagons (also useful for creating silkscreen to be copied to the Footprint Editor in KiCad 6
, beside pads themselves). For (explicitly selected) NPTH pads (mounting holes), it could be necessary to (temporarily) set their pad clearance to the surrounding zone clearance or the copper-to-hole clearance of the board.
oktizer.py (21.7 KB)
Examples:
Example of NPTH rule area (keepout zone):
Example of manually created T-junction (i.e. set grid size to smallest track width):
Example of manually created thermal relief on chamfered rectangle pad:
Elektuur Style Symbol & Footprint Library
The symbols (only) can also be installed on KiCad 6 with Tools → Plugin and Content Manager (PCM). To add the library after installing, use Preferences → Manage Symbol Libraries… followed by Add empty row to table (the +
icon) with the Library Path given in the content description.
The libraries and demos are as well in the repository for local installation using Tools → Plugin and Content Manager → Install from File…. The zip files with demo in their name are example projects (use File → Unarchive Project… instead of PCM). Version 0.5.4 are KiCad 5 libraries (that can also be used and migrated in KiCad 6), version 0.6.4 are KiCad 6 libraries. Currently, the symbols are identical except for some arc adjustments and a few added chamfered footprints (and corresponding config files).
Elektuur (now Elektor) style symbols as introduced in the later 1970s (until the early 1990s when they became more angular). The symbol size has been increased by 1.6% (2 mm grid to 80 mil grid) and the pins realigned to a 100 mil grid.
It’s a generic symbol library (UJT, BJT, JFET, MOSFET, C, D, LED, LDR, Schottky D, Zener D, varicap D, L, P, R, NTC/PTC R, VDR, Re, S, La, LS, Mic, GND, Xtal, F, battery, meter, terminal, jumper, heatsink, opamp, inverter, AND/NAND/OR/NOR/XOR/XNOR, NOT, SCR, triac, plug/socket, TP, arrow) and some single-pad prototype footprints (generated with oktizer.py
above) optimized for some specific track widths. Most symbols have alternat(iv)e/multiple shapes (also KiCad-historically referred to as De Morgan conversion).
kicad-elektuur-symbols-demo-0.5.4.zip (50.9 KB)
Recommended settings for KiCad 6.0 (on Windows) [or copy and modify file *.kicad_pro
from demo]:
Preferences
Preferences…
Common
Antialiasing
Accelerated graphics: High Quality Antialiasing
Fallback graphics: High Quality Antialiasing
Schematic Editor
Display Options
☑ Fallback graphics
Editing Options
☐ Automatically place symbol fields
Symbol Editor
Display Options
☑ Fallback graphics
Editing Options
Default line width: 0 mm 0 mil (broken)
File
Schematic Setup…
General
Formatting
Default line width: 0.254 mm 10 mil
Pin symbol size: 0 mm 0 mil
Junction dot size: Small
Project
NetClasses
Default
Wire thickness: 0.254 mm 10 mil
View [or right mouse button]
Grid Properties…
Grid: 2.54 mm 100 mil
Grid 1: 0.635 mm 25 mil [text or wires of gate/diagonal alt. shape]
Grid 2: 0.254 mm 10 mil [transformer]
Inspect
Simulator
Simulation
Settings…
☑ Adjust passive symbol values (e.g. M → Meg; 100 nF → 100n)
Compatibility mode: PSpice and LTspice
Note: In KiCad 6.99 there is now an alternative to unchecking Automatically place symbol fields
(but it will need modification of the Value/Rating/Indicator/IndicatorControl fields of the symbols).
Recommended settings for KiCad 5.1 (on Windows):
Preferences
Modern Toolset (Fallback) [✓ select this]
Preferences…
Common
Graphics (Fallback): High Quality Antialiasing
Eeschema
Display Options
Wire thickness: 10 mil
Junction size: 40 mil
Symbol Editor
Default line width: 10 mil
Grid Settings…
Grid size: 100 mil [50 mil for diagonal alt. shape]
[25 mil for text or wires of gate alt. shape]
[10 mil for transformer]
Eeschema
Tools
Simulator
Simulation
Settings…
Above SVG
file was created using File → Plotting… with Default line width of 0.254 mm
or 10 mil
, Black and White and PDF
selected, and after repeated Edit → Select All and Object → Ungroup in Inkscape
saved as Optimized SVG
See also Elektuur Retro Lettering (oktuur.zip for Inkscape/SVG).
See also Getting Started with KiCad EDA - Eeschema Schematic Capture (Elektor TV video).
