Eeschema not responding when opening Schematicac
When I go to open a schemtic from a project eeschema window opens but become non responsive and has to be force closed. All other aspects of the program will open. I have tried:
-deleting settings files
-uninstalling and re installing
-uninstalling 5.1.5_3 and installing 5.1.5_2
It is happening with all projects and the projects will load on a different machine running KiCad 5.1.5_3.
Any help would be appreciated.
Vesrion Info
Application: KiCad
Version: (5.1.5)-2, release build
wxWidgets 3.0.4
libcurl/7.66.0 OpenSSL/1.1.1d (Schannel) zlib/1.2.11 brotli/1.0.7 libidn2/2.2.0 libpsl/0.21.0 (+libidn2/2.1.1) nghttp2/1.39.2
Boost: 1.71.0
Curl: 7.66.0
Compiler: GCC 9.2.0 with C++ ABI 1013
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=OFF
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_PYTHON3=OFF
KICAD_SCRIPTING_WXPYTHON=ON
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
Update, I changed the canvas type in \AppData\Roaming\kicad\eeschema from 1 to 2 and it will now load. I have no idea why this fixed the issue. Is anyone able to provide some insight.
canvas_type 1 is OpenGL. If that is not loading on your system, then there may be a driver issue. canvas_type 2 is Cairo, which is software-only so it does not have the same dependencies but it much slower.
I have this same issue. I’ve searched for OpenGL drivers and have only found that they are usually bundled with your drivers for video card. If there is a OpenGL standalone driver that can be used to fix this I haven’t found it. I’ve also had this issue with PCBnew.
I’m having the same problem, and I’ve looked in my \AppData\Roaming\kicad\ directory for an eeschema file with no luck. What else can I do to make the application run correctly?
Have you tried the canvas type 2 suggestion from a few post above?
