I want to load a contour from a *.dxf file into Pcbnew. Here the file: pcb_outline.dxf (20.0 KB)
[5.1.9]
Using File>Import>Import Graphics… works as expected. The contour is loaded into the selected layer.
[5.99]
Using File>Import>Graphics… results in a contour on the selected layer that lacks all curved lines. Only straight lines are imported.
Do I do something wrong or is this a bug (and if so, where should I report it)?
