I want to sim this ckt but having error “Timestep too small”
For switched power electronics applications, I usually have to adjust some of the simulations options:
.options method=gear chgtol=1e-11 abstol=1u reltol=0.01 rshunt=1G rseries=0.05 cshunt=1p trtol=1
It’s helpful to look them up in the ngspice manual so you have an idea what you are changing there. Also consider to add a load to the output.
Have you carefully inspected your circuit? I’m not sure it should work, regardless of the simulation system. (Check the power symbols, and the on/off and probably everything else including diode models)
EDIT: removed, I apologize
I think this IC can be setup as an inverting regulator.
@lucas, you are right, TI datasheet Fig. 8.4.
So, I got curious and set up this circuit. I am able do simulate the circuit with kicad/ngspice. The simulation is kind of slow and I cannot verify it behaves correctly. I had to change something inside of TI’s model file though. I replaced all "GND"s with “trickGND”. Otherwise it seems like the IC doesn’t control the output voltage. @holger Is it possible that the GNDs inside the model could be conflated with the circuit GND during simulation? Attached you’ll find my project.
LM2596.zip (13.6 KB)
GND is a global node in ngspice and will be replaced by 0 everywhere, except for: add set no_auto_gnd to .spiceinit.
