Division of two signals in the analysis plot pane
is there a trick to divide two signals in the plot pane? Subtraction and addition is working.
Kind regards,
S
There is a bug, either in Eeschema or in ngspice. I will check it.
For now, don’t label the node by ‘out1’, but for example by ‘outa’.
Or you may use global labels instead of netlabels.
Hello Holger,
it’s still not working with renaming to ‘Outa’:
Using global labels isn’t working too:
And I would like to kindly ask if there’s a possibility like in LTSpice to add several plot panes to one analysis tab? This is really helpful if the signals are on different DC-levels:
The simulation:
JFET.zip (14.1 KB)
The used JFET model:
jfex140.lib (2.4 KB)
Kind regards,
S
The “trick” of the global lables is that the node now is called ‘out1’, not ‘/out1’ (This helps ngspice by avoiding math characters like ‘/’ in a node name). So you have to adapt the ‘user defined signals’ to the new node names (without ‘/’) as well.
Your JFET.zip is running, but delivers another error meaasge. V(/out1)/V(/G) is running out of range, as V(/G) will be 0 at some point in time (KiCad 8.0.4 on MS Windows).
v2#branch                          5.31501e-11
 Reference value :  0.00000e+00
No. of Data Rows : 1008
let user0 = V(/D)-V(/S)
let user1 = V(/Out1)/V(/G)
Error: argument out of range for divide
in term: V("/Out1")/V("/G")
Error: Can't evaluate " V("/Out1")/V("/G")"
Several plot panes are currently not supported. You may employ ‘user defined signal’ instead by adding an offset. There is already a wishlist item at whishlist: support dual plot pane in simulator (#15960) · Issues · KiCad / KiCad Source Code / kicad · GitLab. You may give it a ‘thumbs up’.
Hi Holger,
thank you for your reply. You are correct there is a division by zero, which leads to the error. If you shift the DC it is doing fine:
I gave a thumbs up. Thank you!
S.
