I’m sure I’m not the first one to struggle with this but I searched the forum without any success.
Here’s the issue: The thermal vias in pads shipped with KiCad footprints have a hole diameter of 0.2mm. Many fab houses only produce 0.3mm an larger, except when it is a via in a pad where the positioning doesn’t have to be that exact.
I want to create a custom rule for that, but I’m not sure it is even possible.
However, this applies to all through-hole pads, not just those that are placed on top of an SMD pad. Is there a way to detect if a PTH is placed on top of an SMD pad?
That being said, at least for JLC the described scenario is irrelevant. I’ve seen some fabs though where they stated something like this. Not sure which though
