I have read
- KiCad 8.0 Creating and editing symbols
- Library Conventions, including S4.2 Pins should be grouped by function
- Creating new library symbol by copying and editing pin order (7.0.11)
- Tutorial: How to make a symbol (KiCad v5.1.x)
From the Library Conventions, this seems clear for simpler devices where one pin has one function
Where possible, pins should be grouped by similar function, rather than by their physical location on the associated footprint. This provides cleaner schematic routing and symbols are easier to understand in the schematic.
I am trying to create a symbol for PJRC Teensy 4.1 where each pin can be configured multiple ways pinout PDF. For example pin 24 could be analog input A10, or serial TX6, or I2C SCL2, or a PWM output.
I had started using an existing symbol, which does not use logical grouping but simply numbers the pins, 1 to 24 on one side and 25 to 49 on the other. But that doesn’t actually correspond to the physical layout, either! Teensy 4.1 is compatible with Teensy 4.0 (and before that, Arduino I think). Teensy 4.0 is shorter, so it has 14 pins on each side [pinout PDF}(https://www.pjrc.com/teensy/card10a_rev2_web.pdf) labelled GND, 0, 1 and so on to 12, then 13 on the other side up to 23 and then three power pins.
To be compatible with that, Teensy 4.1 has GND, 0, 1 and so on to 12, then another power pin, then 24 to 32. On the other side 33 to 41, GND, and (in the same physical positions as Teensy 4.0) 13 to 23, etc.
So the symbol I have been using does not correspond to either the logical or the physical layout, and the pin numbers do not correspond to the device pin numbers either (Teensy pin 1 (TX1) is numbered 3 on the symbol, because the numbering starts at 1. This caused me to lose a bunch of time during schematic capture because I was making incorrect assumptions about how the pins were numbered.
So: making a set of separate symbols for each possible pin usage seems cumbersome and effectively would mean one symbol per project. Thus, I am considering making a symbol that corresponds to the actual physical layout and to the Teensy pin numbering.
On to my actual questions:
Do pins on a KiCad symbol all have to be numbered, and do they have to be sequential? Or can I make a symbol where the first pin is called GND, the second 0, the third 1 and so on?
