In the footprint library manager, if you edit a footprint, you can edit the properties of a pin once. But if you edit the properties of a second pin, it just crashes
Laurent
Laurent
This is a link to a full post formatted such that you can see a preview. Click the title or the arrow in the top right corner to see the full text.
You will also need to post the Version Info detail from Help - About KiCad
There is no such thing as 6.0.0RC1 and won’t be for years
This has cropped here somewhere before
Application: kicad
Version: 6.0.0-rc1-unknown-6db71cd~84~ubuntu18.04.1, release build
wxWidgets 3.0.4
libcurl/7.58.0 OpenSSL/1.1.0g zlib/1.2.11 libidn2/2.0.4 libpsl/0.19.1 (+libidn2/2.0.4) nghttp2/1.30.0 librtmp/2.3
Platform: Linux 4.15.0-32-generic x86_64, 64 bit, Little endian, wxGTK
wxWidgets: 3.0.4 (wchar_t,wx containers,compatible with 2.8) GTK+ 2.24
Boost: 1.65.1
Curl: 7.58.0
Compiler: GCC 7.3.0 with C++ ABI 1011
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=OFF
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_WXPYTHON=OFF
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
6.0.0RC1 = nightly build.
And hopefully the OP submitted a bug report. That is exactly why the nightlies are available. So we need not belabor the point once we’ve pointed him to the correct procedure for reporting bugs.
Well, I got the same issue on version 5.
Laurent
And have you checked the bug list for similar or registered your own?
V5.0.0 crashes are very important and get fixed when raised.
