Copper Pour Area Editing
Folks,
I am new to this forum, so feel free to direct me elsewhere if this post is in the wrong place or this question has already been answered.
I come from a background in Altium, back when I got a free license for being an undergraduate. I have started to do open source hardware design, which I will be documenting in a blog at some point, and made the switch to Kicad. I do not expect the level of complexity that Altium has from KiCad, I am just curious!
Simply put, if you have a board with isolated grounds and multiple voltages, you will end up with many,sometimes odd shaped, copper pours. If I make a copper pour, and then move some components and now my copper pour is in the way, leaving some slivers that I don’t want. Now I want to delete a part of that copper pour, but not the whole thing. The only way I found that I can do that in Kicad is to redraw the entire pour, which can be annoying if you have 20 points to click on to create the pour. In Altium you can click on the pour itself and in the popup menu you can edit the location of the vertices of the pour, which is convenient.
Is there a better way to do this than re-drawing the pour? Or is this a feature I should suggest, and if so where can I go to suggest new KiCad features?
Thanks!
Ldoiron17
Unfortunately the pours are not done exactly like the traces (where you can remove certain segments at a time).
First, select the pour tool and right click over top of the pour and chose to ā€œRemove Filled Areasā€. Then when it’s just the outline of the pour area once again, you can manipulate the zone using ā€œGā€ (grab the zone and drag the segment around), ā€œMā€ (which moves the entire pour area shape around), ā€œAdd cutout areaā€ (via the right click context menu, allows you to modify the zone by drawing new areas you don’t want" or ā€œCreate cornerā€ (via the right click context menu, creates more segments you can drag around using the grab command). Note that to get the ā€œZonesā€ context menu you need to right click directly over the outline of the zone, which is why removing the filled area helps.
For more on this topic, I made a video about creating pours: https://www.youtube.com/watch?v=WcdJ7FAmD7
And modifying copper pour parameters: https://www.youtube.com/watch?v=Y0v8-lTPn-U
You sir are awesome. I actually think that the way that KiCad edits pours is preferable to the way that Altium does it, or the way that I did it in Altium anyway.
Thanks!
This topic is a bit aged, but I’ve just now come across it due to just having the same need.
Unfortunately, when I close a perimeter for a cutout area, KiCAD crashes immediately. I suppose I will file a bug…
These sound like two different things ?
If you have issues with Zones start with a simple board and simplest of Zones, and check that works,
Then, start getting more complex, until something breaks…
In most CAD pgms, there is a shrink step, where the zone-border is what you draw, but the real world requires some line width is used to plot the fill, so the SW shrinks the border.
Sometimes, that shrink can fail, usually on cases where the half-width removal, results in a narrow segment trying to go < 0 length.
ie avoid very short line segments.
Not two different things at all. ChrisGammel mentions:
I’ve narrowed it down to the case where a cutout zone overlaps the edge of a pour zone.
Selecting ā€œAdd cutout areaā€ puts the mouse into polygon mode (i.e. each click places another point in a polygon). As soon as I right-click and select ā€œClose Zone Outlineā€, pcbnew crashes. You can try it yourself:
  1. Launch KiCad and create a new project
  2. Start pcbnew
  3. Use the Copper Pour tool to create a single rectangular copper pour area
  4. Right-click on the pour outline, select Zones -> Add Cutout Area
  5. Draw a polygon that crosses the edge of the pour.
  6. Right-click and choose ā€œClose Zone Outlineā€
Poof!
Anyway, I’ve reproduced it with the latest source, so I’m off to file a bug.
Interesting - that’s only in legacy mode, but it is a slight variant of Add-Cutout
In this pathway, it acts like a nibbler, and will add slices into the existing cutout outline, if the added polygon crosses the outline. Once done, the construction line vanishes. Quite nice.
It does not seem to need an explicit ā€œClose Zone Outlineā€ to work.
Works for me, I’ve nibbled into an Outline in 4 places, and also added a void inside the outline.
Seems to also be ok with a tangent case (shared side)
Tested : Win64 build. r7066
Hi PCB_Wiz,
Turns out it’s only an issue in a Debug build of KiCAD. I have forked KiCAD to add support for database-driven symbol and footprint libraries, so I was running a Debug build. There is an assert that fails. In a release build, everything is copacetic…EXCEPT…for me, after I make the first cutout, the ā€œClose Zone Outlineā€ option in the right-click menu is gone! I can’t close another outline until I restart pcbnew. I assume that is also not a problem for you, since you described making several cutouts.
What is the ā€œAdd-Cutoutā€ thing you are talking about, if not from the step-4 I described? If there’s another path that works more reliably, I’m all ears!
I’ve used the right-menu Add-void, and tick no-copper, to add simple no-copper areas, inside a zone.
If you want to modify the outline itself, and keep it in one-block, the legacy-canvas option you use sounds better, (when it works :wink: )
Hmm, what version of KiCAD are you using? My right-click menu in pcbnew does not have an ā€œAdd Voidā€ entry. I’m using the latest development version, built from source… :slight_smile:
oops, I see it on the right-side-menu, called ā€˜Add keepout areas’, not ā€˜add void’
Ah, I see. Note that what you describe is not the same thing. You are describing adding a keepout, which would affect all zones that it overlaps, and exists as a separate entity in the layout. The OP and I are looking to modify the actual pour zone’s polygon, i.e. add edges to the polygon. That’s what using the zone tool to add a cutout zone does, and only affects the zone being modified.
Anyway, I’ve submitted my bug reports and know how to skate around the issues. Thanks for engaging, PCB_Wiz!
Yes, I already stated that.
There is also an Add-Corner, in both Legacy and OpenGL. More mouse clicks to add a notch, but it may be more stable for you ?
I was unable to crash my Win64, r7066 build.
The crash only affects Debug builds on Unix-like platforms (where a debug assert() calls abort()).
