Could some explain to me on how to use the ‘Circular Array Tool’?
It’s so damn UN-intuitive.
All I want is a circular array 270 degrees with about a 12mm diameter.
This is for polygon line tool, I making line tics for a pot on the front silk layer.
It takes a little practice. Since a picture is worth 1k words… The key thing is to note the required origin, it’s easiest if it is at an offset of 0, 90, 180 deg, otherwise you need to calculate the origin with trig.
thanks, It took some practice but I think I got it now.
How ever I’m having problems with text.
When I right click on a text object i don’t get the ‘Create Array’ option.
How do i get the numbers on my ticks like you did?
I think you should restrict it to 10. Otherwise it’s dangerous because of competition; now everyone can just add one more than the others have. There’s no end to that arms race.
There seems to be an empty repo under the kicad github. (It does however contain a wiki. Just no footprint wizards yet.) I am not certain how official it is. Maybe @SchrodingersGat knows more about it.
Depends on where you installed KiCad, but on my system the folder is C:\Programs\KiCad\share\kicad\scripting\plugins. If you installed into C:\Program Files, you probably need admin access to copy the file there.
Maybe because it is kind of invisible. Should we link to it from the kicad.org homepage? Or at least pin it to the kicad github page. The same would then apply for the templates repo.
Or should we start a general scripting repo instead? (Maybe the footprint wizard stuff can then be a supdirectory of this larger repo.)
Another part would be scripts that use the pcb_new/footprint editor python api. (Action plugins. Examples would be the stuff that @HiGreg made. )
And maybe even standalone stuff. (the test scripts, footprint generators, …)
Should we talk to the developers about that? (It would make sense that the footprint wizards that are currently supplied with kicad would also reside in this repo.)
