I’m trying to use a PSpice model I download from TI website CSD18510Q5B
However, I get a ton of errors from the simulator when trying to do any analysis (see below). I’ve also provided the .lib file from TI. When I use a PSpice model from Infineon, it works just fine (also provided). Is there an issue with the TI .lib file?
Note: No compatibility mode selected!
Warning: redefinition of .subckt csd18510q5b, ignored
Circuit: KiCad schematic
Netlist line no. 0:
Undefined parameter [pwidth]
Netlist line no. 0:
Cannot compute substitute
Netlist line no. 0:
Netlist line no. 0:
Netlist line no. 0:
Netlist line no. 0:
Expression err: pwidth/2}
Netlist line no. 0:
Netlist line no. 0:
Netlist line no. 0:
Netlist line no. 0:
Netlist line no. 0:
Netlist line no. 0:
Netlist line no. 0:
Netlist line no. 0:
Undefined parameter [prgate]
Netlist line no. 0:
Netlist line no. 0:
Undefined parameter [pcjo]
Netlist line no. 0:
Netlist line no. 0:
Undefined parameter [ptrc1]
Netlist line no. 0:
Please check your input netlist.
Error: ngspice.dll cannot recover and awaits to be detached
Note: can't find the initialization file spinit.
** ngspice-39 shared library
** Creation Date: Feb 13 2023 06:17:03
Circuit: *
Warning: No job (tran, ac, op etc.) defined:
run simulation not started
TI File
* CSD1810Q5B
* (C) Copyright 2017 Texas Instruments Incorporated. All rights reserved.
** This model is designed as an aid for customers of Texas Instruments.
** TI and its licensors and suppliers make no warranties, either expressed
** or implied, with respect to this model, including the warranties of
** merchantability or fitness for a particular purpose. The model is
** provided solely on an "as is" basis. The entire risk as to its quality
** and performance is with the customer
* Released by: WEBENCH(R) Design Center, Texas Instruments Inc.
* Part: CSD1810Q5B
* Date: 06AUG2018
* Model Type:
* Simulator: PSPICE
* Simulator Version: 16.2.0.p001
* EVM Order Number:
* EVM Users Guide:
* Datasheet: SLPS632 –MARCH 2017
* Model Version: Final 1.00
* PSpice Model Editor - Version 16.6.0
* CSD18510Q5B - PSpice Model for use with OrCAD/Allegro *
* Characteristics:
* Technology: n-channel 40/20
* Assembly: QFN5x6
* Model History
* Initial model. gd 01/30/2017
* Updated model, gd 11/20/2017
* SUBCKT Definition: 1=D 2=G 3=S
.SUBCKT csd18510q5b 1 2 3
.PARAM ptrc1 7.11e-3
.PARAM ptrc2 2.34e-5
.PARAM pAA 10.856327
.PARAM pwidth {pAA/0.8*2}
.PARAM perim {2.1*pwidth}
.PARAM perp {1.01*pwidth}
.PARAM pRgate 0.90
.PARAM pCJO 62e-12
M1 10 11 12 12 NMOS W={pwidth} L=0.65u PD={0} PS={perim}
M2 12 11 12 20 PMOSd W={pwidth} L=0.067u PS={perp} PD={perp}
DDx 20 10 DD
DBD 8 7 DBD {pwidth/2}
RDB 8 7 8e10
CGD0 5 7 0.5e-12
CGS0 5 8 100e-12
CDS0 10 12 {7.9e-12 * pwidth}
DGD 14 10 DD {pwidth}
DDG 14 5 DD {pwidth}
RDC 14 5 1e10
LGG 2 5 1.7e-9
RGG 5 11 {0.6 + pRgate}
RSB 12 9 RTEMP 0.01e-3
RSS 9 8 RTEMP 0.08e-3
RSP 8 6 0.07e-3
LSS 6 3 0.40E-9
RDP 4 7 0.02e-3
RDD 7 10 RTEMP 0.457e-3
LDD 1 4 0.1E-9
.MODEL NMOS NMOS ( LEVEL = 7 Version = 3.2
+ TNOM = 27 LINT = 0.060e-6 CAPMOD = 2
+ TOX = 5.50e-8 NCH = 1.330e17 NSUB = 8.0e15
+ AGS = 0.0 PVAG = 0.0 VOFFCV = 0.3
+ U0 = 360 VSAT = 8.4e4
+ A0 = 2.2 A1 = 0.1 A2 = 1.0
+ UA = 0.9e-9 UB = 8e-19 VBM = -10.0
+ UA1 = 3.3e-9 UB1 =-1e-19 UTE = -0.60
+ KT1 = -0.91 KT2 = 0.022 KT1L = 1.0e-10
+ DVT0 = 2.15 DVT1 = 0.54 DVT2 = -0.033
+ ETA0 = 0.05 ETAB = -0.07 XJ = 3e-7
+ PDIBLC1= 0.50 PDIBLC2= 0.012 NLX = 1.74e-7
+ PSCBE1 = 4.2e8 PSCBE2 = 2.5e-6 PCLM = 1.3
+ VOFF = -0.32 NFACTOR= 1.18 JS = 0
+ DROUT = 0.88 DSUB = 0.90 DELTA = 0.09
+ CJ = 1e-18 CJSW = 1e-18 CF = 0
+ CGSO = 25e-12 CGDO = 15.2e-12 CGBO = 0 )
.MODEL PMOSd PMOS ( LEVEL = 3
+ TNOM = 27 VTO = -5 IS = 1.0e-18
+ TOX = 5.5e-8 NSUB = 1e16
+ CGSO = 1e-18 CGDO = 1e-18 CGBO = 0 )
.MODEL DBD D (CJO=550e-12 VJ=0.99 M=1.14 FC=0.5 TT=3e-09 TNOM=27
+ IS=5.7e-12 N=1.055 RS=7.8e-3 TRS1=3.5e-3 TRS2=-1.0e-6 XTI=3.2
+ BV=42 TBV1=8.4e-4 TBV2=-2.3e-6 NR=3.3 ISR=2.35e-10)
.MODEL DD D (CJO={2*pCJO} VJ=0.78 M=1.68 IS=1e-15 RS=10 TNOM=27
+ FC=0.90 )
.MODEL RTEMP RES (TC1={ptrc1} TC2={ptrc2})
.ENDS csd18510q5b
Infineon File:
* INFINEON Power Transistors *
* PSPICE Library for *
* OptiMOS 34V *
* n-channel Transistors *
* Version 210513 *
* The Simulation Model is subject to change without notice. In *
* addition, models can be a useful tool in evaluating device *
* performance, they cannot reflect the accurate device *
* performance under all conditions, nor are they intended to *
* replace bread boarding for final verification. Infineon *
* therefore does not assume any warranty or liability *
* whatsoever arising from their use. Infineon does not assume *
* any warranty or liability for the values and functions of the *
* Simulation Model. *
* The methods and results of the Simulation Model are to the *
* best of our knowledge *
* correct. However, the user is fully responsible to verify and *
* validate these results under the operating conditions and in *
* the environment of its application. Infineon will not bear *
* the responsibility arising out of or in connection with any *
* malfunction of the Simulation Models. *
* Models provided by Infineon are not warranted by Infineon as *
* completely and comprehensively representing all the *
* specifications and operating characteristics of the *
* semiconductor products to which these models relate. The *
* models describe the characteristics of typical devices. In *
* all cases, the current data sheet information for a given *
* device is the conclusive design guideline and the only actual *
* performance specification. *
* This library contains models of the following INFINEON *
* transistors: *
* OptiMOS 34V *
* BSC0908NS BSC0909NS BSZ0909NS *
* thermal nodes of level 3 models: *
* .SUBCKT BSC010NE2LS drain gate source Tj Tcase *
* Tj : potential=temperature (in °C) at junction (typically *
* not connected) *
* Tcase : node where the boundary contition - external heat *
* sinks etc - have to be connected (ideal heat sink *
* can be modeled by using a voltage source stating the *
* ambient temperature in °C between Tcase and ground. *
.SUBCKT S4_34_h_var dd g s0 Tj PARAMS: a=1 dVth=0 dR=0 dgfs=0 Inn=1 Unn=1 Rmax=1
+gmin=1 Rs=1 Rp=1 dC=0 Rm=1u
.PARAM Fm=0.2 Fn=0.5
.PARAM c=1.5125 Vth0=2.73 auth=2.35m
.PARAM UT=100m ab=20m lB=-23 UB=39.4
.PARAM b0=164 p0=7.71 p1=-33m p2=54u
.PARAM Rd=6.15m nmu=3.21 Tref=298 T0=273 lnIsj=-25.6
.PARAM ndi=1.1 Rdi=2.19m nmu2=0.55 ta=3n td=20n
.PARAM Rf=0.722 nmu3=1.38
.PARAM f1=210p f2=680p f3=950p U0=12 nc=2 nd=1.3
.PARAM g1=0.15 bb=1 remp=0.01p f2r=400p
.PARAM kbq=85.8u
.PARAM Vmin=2.33 Vmax=3.13 dCmax=0.33
.PARAM Vth={Vth0+(Vmax-Vth0)*limit(dVth,0,1)-(Vmin-Vth0)*limit(dVth,-1,0)}
.PARAM q0={b0*((T0/Tref)**nmu3)*a}
.PARAM q1={(Unn-Inn*Rs-Vth0)*q0}
.PARAM q2={(Fm*SQRT(0.4)-c)*Inn*q0}
.PARAM Rlim={(q1+2*q2*Rmax-SQRT(q1**2+4*q2))/(2*q2)}
.PARAM dRd={Rd/a+if(dVth==0,limit(dR,0,1)*max(Rlim-Rd/a-Rs-Rp,0),0)}
.PARAM bm={c/((1/gmin-Rs)**2*Inn*a*(T0/Tref)**nmu3)}
.PARAM bet={b0+(b0-bm)*if(dR==0,if(dVth==0,limit(dgfs,-1,0),0),0)}
.PARAM dC1={1+dCmax*limit(dC,0,1)}
.PARAM dC2={1+1.5*dCmax*limit(dC,0,1)}
.PARAM Cox={f1*a*dC2}
.PARAM Cox1={remp*SQRT(a)*dC2}
.PARAM Cds0={(f2*a+f2r*SQRT(a))*dC1}
.PARAM Cgs0={f3*a*dC1}
.PARAM dRdi={Rdi/a}
.FUNC I0(Uee,p,pp,z1) {if(Uee>pp,(Uee-c*z1)*z1,p*(pp-p)/c*exp((Uee-pp)/p))}
.FUNC Ig(Uds,T,p,Uee) {bet*(T0/T)**nmu3*I0(Uee,p,min(2*p,p+c*Uds),min(Uds,Uee/(2*c)))}
.FUNC J(d,g,T,da,s)
+ {a*(s*(Ig(da,T,(p0+(p1+p2*T)*T)*kbq*T,g-Vth+auth*(T-Tref)+Fm*da**Fn+1*limit(-d,0,1))+exp(min(lB+(da-UB-ab*(T-Tref))/UT,25))))}
.FUNC Idiode(Usd,Tj,Iss) {exp(min(log(Iss)+Usd/(ndi*kbq*Tj),7))-Iss}
.FUNC Idiod(Usd,Tj) {a*Idiode(Usd,Tj,exp(min(lnIsj+(Tj/Tref-1)*1.12/(ndi*kbq*Tj),7))*(Tj/Tref)**3)}
E_Edg d ox VALUE {max(V(d,g),-bb)-(1/(g1*(1-nc))*((1/(1+g1*max(V(d,g)+bb,0)))**(nc-1)-(1/(1+g1*bb))**(nc-1)))}
C_Cdg ox g {Cox}
Vx d ox1 0
C_Cdg1 ox1 g {Cox1}
E_Eds d edep VALUE {(V(d,s)-I(V_sense3)/Cds0)}
C_Cds edep s {Cds0}
C_Cgs g s {Cgs0}
G_chan d s VALUE={J(V(d,s),V(g,s),T0+limit(V(Tj),-200,300),abs(V(d,s)),sgn(V(d,s)))}
G_RMos d1 d VALUE={V(d1,d)/(Rf*dRd+(1-Rf)*dRd*((limit(V(Tj),-200,999)+T0)/Tref)**nmu)}
V_sense dd d1 0
G_diode s d3 VALUE={Idiod(V(s,d3),T0+limit(V(Tj),-200,499))}
G_Rdio d2 d1 VALUE={V(d2,d1)/(dRdi*((limit(V(Tj),-200,999)+T0)/Tref)**nmu2)}
V_sense2 d2 d3 0
L_L001 a c {td/(ta+td)}
R_R001 a b {1/ta}
V_sense3 c 0 0
E_E001 b 0 VALUE {I(V_sense2)}
E_E002 e 0 VALUE {Cds0*1/(1-nd)*U0**nd*(limit(U0+V(d1,s),0,2*UB))**(1-nd)}
R_R002 e c 1
R_R003 a 0 500Meg
R1 g s 1G
Rd01 d s 500Meg
Rd02 d2 s 500Meg
Rd03 d1 d 1k
Rmet s s0 {Rm}
G_TH 0 Tj VALUE =
+{(LIMIT(I(V_sense2)*V(d1,s)+(V(s,s0)**2)/Rm+(I(V_sense)-I(V_sense2))*V(d1,d)+
+(I(V_sense)-I(V_sense2)-I(E_Edg)-I(Vx)-I(E_Eds))*V(d,s),-10k,100k))}
.ENDS
.SUBCKT S4_34_h_var1 dd g s0 Tj PARAMS: a=1 dVth=0 dR=0 dgfs=0 Inn=1 Unn=1 Rmax=1
.PARAM kbq=85.8u
.PARAM dRdi={Rdi/a}
.FUNC J(d,g,T,da)
+ {a*(sgn(d)*Ig(da,T,(p0+(p1+p2*T)*T)*kbq*T,g-Vth+auth*(T-Tref)+Fm*da**Fn+1*limit(-d,0,1)))}
C_Cdg ox g {Cox}
C_Cdg1 d g {Cox1}
E_Eds d edep VALUE {V(d,s)-1/(1-nd)*U0*((limit(1+V(d,s)/U0,0,2*UB))**(1-nd)-1)}
C_Cds edep s {Cds0*0.99}
Dbody s dd dbody
.model dbody D (BV= {UB},CJO ={Cds0/100},TT ={ta},IS ={a*exp(lnIsj)} m={0.3} RS={dRdi} )
C_Cgs g s {Cgs0}
G_chan d s VALUE={J(V(d,s),V(g,s),T0+limit(V(Tj),-200,300),abs(V(d,s)))}
G_RMos dd d VALUE={V(dd,d)/(Rf*dRd+(1-Rf)*dRd*((limit(V(Tj),-200,999)+T0)/Tref)**nmu)}
R1 g s 1G
Rd01 d s 500Meg
Rd03 dd d 1k
Rd04 g d 500Meg
Rmet s s0 {Rm} TC=4m
Rx Tj 0 1k
.ENDS
.SUBCKT S4_34_m_var dd g s0 Tj PARAMS: a=1 dVth=0 dR=0 dgfs=0 Inn=1 Unn=1 Rmax=1
.PARAM Fm=0.15 Fn=0.5 al=0.5
.PARAM c=2.04 Vth0=2.355 auth=2.485m
.PARAM UT=100m ab=20m lB=-23 UB=39.9
.PARAM b0=229 p0=5.803 p1=-21.2m p2=35.5u
.PARAM Rd=6.3m nmu=3.05 Tref=298 T0=273 lnIsj=-25.727
.PARAM ndi=1.113 Rdi=2.1m nmu2=0.70 ta=3n td=20n
.PARAM Rf=0.675 nmu3=1.5
.PARAM f1=280p f2=680p f3=1.15n U0=12 nc=2 nd=1.3
.PARAM kbq=85.8u
.PARAM Vmin=1.855 Vmax=2.855 dCmax=0.33
.PARAM dRdi={Rdi/a}
.FUNC J(d,g,T,da,s)
+ {a*(s*(Ig(da,T,(p0+(p1+p2*T)*T)*kbq*T,g-Vth+auth*(T-Tref)+Fm*da**Fn+1*limit(-d,0,1))+exp(min(lB+(abs(d)-UB-ab*(T-Tref))/UT,25))))}
C_Cdg ox g {Cox}
Vx d ox1 0
C_Cdg1 ox1 g {Cox1}
C_Cds edep s {Cds0}
C_Cgs g s {Cgs0}
G_chan d s VALUE={J(V(d,s),V(g,s),T0+limit(V(Tj),-200,300),(SQRT(1+4*al*abs(V(d,s)))-1)/2/al,sgn(V(d,s)))}
V_sense dd d1 0
V_sense2 d2 d3 0
R_R001 a b {1/ta}
V_sense3 c 0 0
R_R002 e c 1
R_R003 a 0 500Meg
R1 g s 1G
Rd01 d s 500Meg
Rd02 d2 s 500Meg
Rd03 d1 d 1k
Rmet s s0 {Rm}
G_TH 0 Tj VALUE =
.ENDS
.SUBCKT S4_34_m_var1 dd g s0 Tj PARAMS: a=1 dVth=0 dR=0 dgfs=0 Inn=1 Unn=1 Rmax=1
.PARAM kbq=85.8u
.PARAM dRdi={Rdi/a}
.FUNC J(d,g,T,da)
C_Cdg ox g {Cox}
C_Cdg1 d g {Cox1}
Dbody s dd dbody
C_Cgs g s {Cgs0}
G_chan d s VALUE={J(V(d,s),V(g,s),T0+limit(V(Tj),-200,300),(SQRT(1+4*al*abs(V(d,s)))-1)/2/al)}
R1 g s 1G
Rd01 d s 500Meg
Rd03 dd d 1k
Rd04 g d 500Meg
Rx Tj 0 1k
.ENDS
.SUBCKT BSC0908NS drain gate source Tj Tcase PARAMS: dVth=0 dRdson=0 dgfs=0 dC=0 Zthtype=0 Ls=0.3n Ld=1n Lg=3n
.PARAM Rs=449u Rg=3 Rd=50u Rm=210u
.PARAM Inn=30 Unn=10 Rmax=8m gmin=27
.PARAM act=1.13
X1 d1 g s Tj S4_34_h_var PARAMS: a={act} dVth={dVth} dR={dRdson} dgfs={dgfs} Inn={Inn} Unn={Unn}
+Rmax={Rmax} gmin={gmin} Rs={Rs} Rp={Rd} dC={dC} Rm={Rm}
Rg g1 g {Rg}
Lg gate g1 {Lg*if(dgfs==99,0,1)}
Gs s1 s VALUE={V(s1,s)/(Rs*(1+(limit(V(Tj),-200,999)-25)*4m)-Rm)}
Rsa s1 s 1Meg
Ls source s1 {Ls*if(dgfs==99,0,1)}
Rda d1 d2 {Rd}
Ld drain d2 {Ld*if(dgfs==99,0,1)}
Rsb source s1 10
Rga gate g1 10
Rdb drain d2 10
Rth1 Tj t1 {23.29m+limit(Zthtype,0,1)*8.62m}
Rth2 t1 t2 {283.61m+limit(Zthtype,0,1)*104.96m}
Rth3 t2 t3 {971.74m+limit(Zthtype,0,1)*397.75m}
Rth4 t3 t4 {1.29+limit(Zthtype,0,1)*418.31m}
Rth5 t4 Tcase {529.89m+limit(Zthtype,0,1)*171.83m}
Cth1 Tj 0 7.866u
Cth2 t1 0 49.331u
Cth3 t2 0 367.399u
Cth4 t3 0 199.127u
Cth5 t4 0 666.043m
Cth6 Tcase 0 30m
.ENDS
.SUBCKT BSZ0909NS drain gate source Tj Tcase PARAMS: dVth=0 dRdson=0 dgfs=0 dC=0 Zthtype=0 Ls=0.3n Ld=1n Lg=3n
.PARAM Rs=935u Rg=3 Rd=50u Rm=520u
.PARAM Inn=20 Unn=4.5 Rmax=15m gmin=18
.PARAM RRf=498m Rrbond=23m Rtb=7.4 g2=964m
.PARAM act=0.825
.FUNC Pb(I,dT,Rb) {Rb/(2*Rtb)*(I-limit(dT/(max(I,1n)*Rb)+RRf*I*g2,0,I))**2}
X1 d1 g s Tj S4_34_m_var PARAMS: a={act} dVth={dVth} dR={dRdson} dgfs={dgfs} Inn={Inn} Unn={Unn}
Rg g1 g {Rg}
Rsa s1 s 1Meg
Rda d1 d2 {Rd}
Rsb source s1 10
Rga gate g1 10
Rdb drain d2 10
G_TH 0 Tb VALUE = {Pb(abs(I(Ls)),V(Tj,Tcase),Rrbond*(1+(limit((V(Tb)+V(Tj))/2,-200,999)-25)*4m))}
Cthb Tb 0 1.71m
Rthb Tb Tj {Rtb}
Rth1 Tj t1 {31.9m+limit(Zthtype,0,1)*11.81m}
Rth2 t1 t2 {379.09m+limit(Zthtype,0,1)*140.29m}**********
.SUBCKT BSC0909NS drain gate source Tj Tcase PARAMS: dVth=0 dRdson=0 dgfs=0 dC=0 Zthtype=0 Ls=0.3n Ld=1n Lg=3n
.PARAM Rs=414u Rg=3 Rd=50u Rm=222u
.PARAM Inn=20 Unn=4.5 Rmax=11.8m gmin=20.45
.PARAM act=0.979
Rg g1 g {Rg}
Rsa s1 s 1Meg
Rda d1 d2 {Rd}
Rsb source s1 10
Rga gate g1 10
Rdb drain d2 10
Rth1 Tj t1 {26.89m+limit(Zthtype,0,1)*9.95m}
Rth2 t1 t2 {323.87m+limit(Zthtype,0,1)*119.86m}
Rth3 t2 t3 {1.12+limit(Zthtype,0,1)*463.25m}
Rth4 t3 t4 {1.49+limit(Zthtype,0,1)*387.27m}
Rth5 t4 Tcase {522.98m+limit(Zthtype,0,1)*135.93m}
Cth1 Tj 0 6.815u
Cth2 t1 0 43.198u
Cth3 t2 0 318.113u
Cth4 t3 0 172.518u
Cth5 t4 0 3m
Cth6 Tcase 0 30m
.ENDS
Rth3 t2 t3 {1.31+limit(Zthtype,0,1)*545.6m}
Rth4 t3 t4 {1.78+limit(Zthtype,0,1)*310.74m}
Rth5 t4 Tcase {502.8m+limit(Zthtype,0,1)*87.77m}
Cth1 Tj 0 5.743u
Cth2 t1 0 36.906u
Cth3 t2 0 275.087u
Cth4 t3 0 145.381u
Cth5 t4 0 3m
Cth6 Tcase 0 10m
.ENDS
.SUBCKT BSC0908NS_L1 drain gate source PARAMS: dVth=0 dRdson=0 dgfs=0 dC=0 Ls=0.3n Ld=1n Lg=3n
.PARAM act=1.13
X1 d1 g s Tj S4_34_h_var1 PARAMS: a={act} dVth={dVth} dR={dRdson} dgfs={dgfs} Inn={Inn} Unn={Unn}
Rg g1 g {Rg}
Rsa s1 s 1Meg
Rda d1 d2 {Rd}
E1 Tj w VALUE={TEMP}
R1 w 0 1u
Rs source s1 5
Rd drain d1 5
.ENDS
.SUBCKT BSZ0909NS_L1 drain gate source PARAMS: dVth=0 dRdson=0 dgfs=0 dC=0 Ls=0.3n Ld=1n Lg=3n
.PARAM act=0.825
X1 d1 g s Tj S4_34_m_var1 PARAMS: a={act} dVth={dVth} dR={dRdson} dgfs={dgfs} Inn={Inn} Unn={Unn}
Rg g1 g {Rg}
Rsa s1 s 1Meg
Rda d1 d2 {Rd}
R1 w 0 1u
Rs source s1 5
Rd drain d1 5
.ENDS
.SUBCKT BSC0909NS_L1 drain gate source PARAMS: dVth=0 dRdson=0 dgfs=0 dC=0 Ls=0.3n Ld=1n Lg=3n
.PARAM act=0.979
Rg g1 g {Rg}
Rsa s1 s 1Meg
Rda d1 d2 {Rd}
R1 w 0 1u
Rs source s1 5
Rd drain d1 5
.ENDS
.SUBCKT BSC0908NS_L0 drain gate source
Lg gate g1 3n
Ld drain d1 1n
Ls source s1 0.3n
Rs s1 s2 449u
Rs1 source s1 5
Rd1 drain d1 5
Rg g1 g2 3
M1 d2 g2 s2 s2 DMOS L=1u W=1u
.MODEL DMOS NMOS ( KP= 120 VTO=2.62 THETA=0 VMAX=1.5e5 ETA=0.015 LEVEL=3)
Rd d1 d2 5.49m TC=7m
Dbd s2 d2 Dbt
.MODEL Dbt D(BV=38 M=0.3 CJO=1.19n VJ=0.9V)
Dbody s2 21 DBODY
.MODEL DBODY D(IS=8.6p N=1.1 RS=0.44u EG=1.12 TT=3n)
Rdiode d1 21 1.94m TC=10m
.MODEL sw NMOS(VTO=0 KP=10 LEVEL=1)
Maux g2 c a a sw
Maux2 b d g2 g2 sw
Eaux c a d2 g2 1
Eaux2 d g2 d2 g2 -1
Cox b d2 0.24n
.MODEL DGD D(M=0.6 CJO=0.24n VJ=0.5)
Rpar b d2 1Meg
Dgd a d2 DGD
Rpar2 d2 a 10Meg
Cgs g2 s2 0.98n
.ENDS BSC0908NS_L0
.SUBCKT BSZ0909NS_L0 drain gate source
Lg gate g1 3n
Ld drain d1 1n
Ls source s1 0.3n
Rs s1 s2 935u
Rs1 source s1 5
Rd1 drain d1 5
Rg g1 g2 3
.MODEL DMOS NMOS ( KP= 110 VTO=2.55 THETA=0 VMAX=1.5e5 ETA=0.011 LEVEL=3)
Rd d1 d2 7.08m TC=7m
Dbd s2 d2 Dbt
.MODEL Dbt D(BV=38 M=0.3 CJO=0.92n VJ=0.9V)
Dbody s2 21 DBODY
.MODEL DBODY D(IS=5.8p N=1.11 RS=0.61u EG=1.12 TT=3n)
Rdiode d1 21 2.55m TC=10m
Maux g2 c a a sw
Maux2 b d g2 g2 sw
Eaux c a d2 g2 1
Eaux2 d g2 d2 g2 -1
Cox b d2 0.23n
.MODEL DGD D(M=0.6 CJO=0.23n VJ=0.5)
Rpar b d2 1Meg
Dgd a d2 DGD
Rpar2 d2 a 10Meg
Cgs g2 s2 0.95n
.ENDS BSZ0909NS_L0
.SUBCKT BSC0909NS_L0 drain gate source
Lg gate g1 3n
Ld drain d1 1n
Ls source s1 0.3n
Rs s1 s2 414u
Rs1 source s1 5
Rd1 drain d1 5
Rg g1 g2 3
.MODEL DMOS NMOS ( KP= 132 VTO=2.55 THETA=0 VMAX=1.5e5 ETA=0.011 LEVEL=3)
Rd d1 d2 5.97m TC=7m
Dbd s2 d2 Dbt
.MODEL Dbt D(BV=38 M=0.3 CJO=1.06n VJ=0.9V)
Dbody s2 21 DBODY
.MODEL DBODY D(IS=6.9p N=1.11 RS=0.51u EG=1.12 TT=3n)
Rdiode d1 21 2.15m TC=10m
Maux g2 c a a sw
Maux2 b d g2 g2 sw
Eaux c a d2 g2 1
Eaux2 d g2 d2 g2 -1
Cox b d2 0.27n
.MODEL DGD D(M=0.6 CJO=0.27n VJ=0.5)
Rpar b d2 1Meg
Dgd a d2 DGD
Rpar2 d2 a 10Meg
Cgs g2 s2 1.13n
.ENDS BSC0909NS_L0
