Cant export step file
****** Statistics on Transfer (Write) ******
****** Transfer Mode = 0 I.E. As Is ******
****** Transferring Shape, ShapeType = 0 ******
** WorkSession : Sending all data
Step File Name : $tempfile$.step(2679451 ents) Write Done
STEP file ‘C:\Users\infos\Downloads\keeboa.step’ created.
Export time 241.863 s
*** Process failed with exit code 2 ***
idk wat this error means
Please report this on GitLab with the full KiCad project (or a minimal example that still has the issue) and 3D models attached.
I have a downloaded project, shared in another thread, How to Set Clearance Between Copper Pours in KiCad 8? - #26 by rayan, with which I tried, and the same error appears. I tried to narrow it down and finally selected only J10 in the board and chose Export components → Only selected. It seems to cause problem with that project setup where the 3D file isn’t actually available (the files, including the footprint file and 3D file, point to folders in the original user’s absolute file system structure).
