Hello all,
I have been working with the latest version of KiCad and I am having a weird problem.
Anytime I edit a single components value (like C-Small to 4.7uF), I suddenly can’t select a different component until I open up another component or power selection box. Any click I make, windows makes the sound as if there is a different window that I’m not seeing. Almost like there is further action necessary after changing a components value.
The only way I’ve found to be able to edit again is to go to the toolbar and select the “place power port” tool and then click in the schematic to bring up the selection window. At which point I’ll cancel out of the window and then I’ll be able to edit another components value.
I have to do that for every component…
