I would really like to be able to use KiCost, and have spent four hours today trying to get it to work, to no avail. I’m trying to install it on a Windows 10 machine. I have an xml BOM file from KiCad 5.x. I followed the installation instructions at kicost.readthedocs.io carefully. I did easy_install kicost, which generated a number of warnings and syntax errors.
C:\Users\Julia>easy_install kicost
Searching for kicost
Reading Links for kicost
c:\users\julia\appdata\local\programs\python\python37\lib\site-packages\setuptools\pep425tags.py:89: RuntimeWarning: Config variable ‘Py_DEBUG’ is unset, Python ABI tag may be incorrect
warn=(impl == ‘cp’)):
c:\users\julia\appdata\local\programs\python\python37\lib\site-packages\setuptools\pep425tags.py:93: RuntimeWarning: Config variable ‘WITH_PYMALLOC’ is unset, Python ABI tag may be incorrect
Downloading https://files.pythonhosted.org/packages/7b/e4/04806a6834df2d056e70c8cf35d7ceb56d22465274e7f66139692c5d2fa7/kicost-1.0.3.tar.gz#sha256=c0187e156352e26d5ada8475f54560c89db7db8cb9d4a825674973b3e8593766
Best match: kicost 1.0.3
Processing kicost-1.0.3.tar.gz
Writing C:\Users\Julia\AppData\Local\Temp\easy_install-rld_95bn\kicost-1.0.3\setup.cfg
Running kicost-1.0.3\setup.py -q bdist_egg --dist-dir C:\Users\Julia\AppData\Local\Temp\easy_install-rld_95bn\kicost-1.0.3\egg-dist-tmp-7xtumm87
c:\users\julia\appdata\local\programs\python\python37\lib\distutils\dist.py:274: UserWarning: Unknown distribution option: ‘long_description_content_type’
warnings.warn(msg)
warning: no previously-included files matching ‘pycache’ found under directory ‘’
warning: no previously-included files matching '.py[co]’ found under directory ‘’
warning: no files found matching '.md’ under directory ‘docs’
File “build\bdist.win-amd64\egg\kicost\kicost_config.py”, line 108
rom kicost.edas import eda_dict
SyntaxError: invalid syntaxFile “build\bdist.win-amd64\egg\kicost\kicost_kicadplugin.py”, line 55
def Run(self):
SyntaxError: import * only allowed at module levelcreating c:\users\julia\appdata\local\programs\python\python37\lib\site-packages\kicost-1.0.3-py3.7.egg
Extracting kicost-1.0.3-py3.7.egg to c:\users\julia\appdata\local\programs\python\python37\lib\site-packages
File “c:\users\julia\appdata\local\programs\python\python37\lib\site-packages\kicost-1.0.3-py3.7.egg\kicost\kicost_config.py”, line 108
SyntaxError: invalid syntaxFile “c:\users\julia\appdata\local\programs\python\python37\lib\site-packages\kicost-1.0.3-py3.7.egg\kicost\kicost_kicadplugin.py”, line 55
def Run(self):
SyntaxError: import * only allowed at module levelAdding kicost 1.0.3 to easy-install.pth file
Installing kicost-script.py script to c:\users\julia\appdata\local\programs\python\python37\Scripts
Installing kicost.exe script to c:\users\julia\appdata\local\programs\python\python37\ScriptsInstalled c:\users\julia\appdata\local\programs\python\python37\lib\site-packages\kicost-1.0.3-py3.7.egg
Processing dependencies for kicost
Searching for babel>=2.6
Reading Links for babel
Downloading https://files.pythonhosted.org/packages/b8/ad/c6f60602d3ee3d92fbed87675b6fb6a6f9a38c223343ababdb44ba201f10/Babel-2.6.0-py2.py3-none-any.whl#sha256=6778d85147d5d85345c14a26aada5e478ab04e39b078b0745ee6870c2b5cf669
Best match: Babel 2.6.0
Processing Babel-2.6.0-py2.py3-none-any.whl
Installing Babel-2.6.0-py2.py3-none-any.whl to c:\users\julia\appdata\local\programs\python\python37\lib\site-packages
writing requirements to c:\users\julia\appdata\local\programs\python\python37\lib\site-packages\Babel-2.6.0-py3.7.egg\EGG-INFO\requires.txt
Adding Babel 2.6.0 to easy-install.pth file
Installing pybabel-script.py script to c:\users\julia\appdata\local\programs\python\python37\Scripts
Installing pybabel.exe script to c:\users\julia\appdata\local\programs\python\python37\ScriptsInstalled c:\users\julia\appdata\local\programs\python\python37\lib\site-packages\babel-2.6.0-py3.7.egg
Searching for CurrencyConverter>=0.5
Reading Links for currencyconverter
Downloading https://files.pythonhosted.org/packages/78/3f/00641ca92805452269d5445ab904c015baef6d452e8732d84e05cea29b6b/CurrencyConverter-0.13.6.tar.gz#sha256=188ea52855a5031608f02ca9ee48e00b61bef499cc7234cb98563f25cf655109
Best match: CurrencyConverter 0.13.6
Processing CurrencyConverter-0.13.6.tar.gz
Writing C:\Users\Julia\AppData\Local\Temp\easy_install-ogpri49o\CurrencyConverter-0.13.6\setup.cfg
Running CurrencyConverter-0.13.6\setup.py -q bdist_egg --dist-dir C:\Users\Julia\AppData\Local\Temp\easy_install-ogpri49o\CurrencyConverter-0.13.6\egg-dist-tmp-zd0_31b4
creating c:\users\julia\appdata\local\programs\python\python37\lib\site-packages\currencyconverter-0.13.6-py3.7.egg
Extracting currencyconverter-0.13.6-py3.7.egg to c:\users\julia\appdata\local\programs\python\python37\lib\site-packages
Adding currencyconverter 0.13.6 to easy-install.pth file
Installing currency_converter-script.py script to c:\users\julia\appdata\local\programs\python\python37\Scripts
Installing currency_converter.exe script to c:\users\julia\appdata\local\programs\python\python37\ScriptsInstalled c:\users\julia\appdata\local\programs\python\python37\lib\site-packages\currencyconverter-0.13.6-py3.7.egg
Searching for requests>=2.18.4
Reading Links for requests
Downloading https://files.pythonhosted.org/packages/f1/ca/10332a30cb25b627192b4ea272c351bce3ca1091e541245cccbace6051d8/requests-2.20.0-py2.py3-none-any.whl#sha256=a84b8c9ab6239b578f22d1c21d51b696dcfe004032bb80ea832398d6909d7279
Best match: requests 2.20.0
Processing requests-2.20.0-py2.py3-none-any.whl
Installing requests-2.20.0-py2.py3-none-any.whl to c:\users\julia\appdata\local\programs\python\python37\lib\site-packages
writing requirements to c:\users\julia\appdata\local\programs\python\python37\lib\site-packages\requests-2.20.0-py3.7.egg\EGG-INFO\requires.txt
Adding requests 2.20.0 to easy-install.pth fileInstalled c:\users\julia\appdata\local\programs\python\python37\lib\site-packages\requests-2.20.0-py3.7.egg
Searching for tqdm>=4.4.0
Reading Links for tqdm
Downloading https://files.pythonhosted.org/packages/91/55/8cb23a97301b177e9c8e3226dba45bb454411de2cbd25746763267f226c2/tqdm-4.28.1-py2.py3-none-any.whl#sha256=3c4d4a5a41ef162dd61f1edb86b0e1c7859054ab656b2e7c7b77e7fbf6d9f392
Best match: tqdm 4.28.1
Processing tqdm-4.28.1-py2.py3-none-any.whl
Installing tqdm-4.28.1-py2.py3-none-any.whl to c:\users\julia\appdata\local\programs\python\python37\lib\site-packages
Adding tqdm 4.28.1 to easy-install.pth file
Installing tqdm-script.py script to c:\users\julia\appdata\local\programs\python\python37\Scripts
Installing tqdm.exe script to c:\users\julia\appdata\local\programs\python\python37\ScriptsInstalled c:\users\julia\appdata\local\programs\python\python37\lib\site-packages\tqdm-4.28.1-py3.7.egg
Searching for yattag>=1.5.2
Reading Links for yattag
Downloading https://files.pythonhosted.org/packages/ba/65/2c62e21d328a8472a438d9d255b69f862d969c703cd1425463bee728f8e8/yattag-1.10.0.tar.gz#sha256=0a3fe7fcbdd5886ebe4ef6c215627599bb13e93a8bc26d3e48789b02e5ddc5dc
Best match: yattag 1.10.0
Processing yattag-1.10.0.tar.gz
Writing C:\Users\Julia\AppData\Local\Temp\easy_install-0gi28_lk\yattag-1.10.0\setup.cfg
Running yattag-1.10.0\setup.py -q bdist_egg --dist-dir C:\Users\Julia\AppData\Local\Temp\easy_install-0gi28_lk\yattag-1.10.0\egg-dist-tmp-a82klhku
zip_safe flag not set; analyzing archive contents…
Copying yattag-1.10.0-py3.7.egg to c:\users\julia\appdata\local\programs\python\python37\lib\site-packages
Adding yattag 1.10.0 to easy-install.pth fileInstalled c:\users\julia\appdata\local\programs\python\python37\lib\site-packages\yattag-1.10.0-py3.7.egg
Searching for lxml>=3.7.2
Reading Links for lxml
Downloading https://files.pythonhosted.org/packages/d7/9d/1aa28aa9d293a816baec6c37328d6465b722b2ff3f4d1e93ed56e87813ee/lxml-4.2.5-cp37-cp37m-win_amd64.whl#sha256=d3266bd3ac59ac4edcd5fa75165dee80b94a3e5c91049df5f7c057ccf097551c
Best match: lxml 4.2.5
Processing lxml-4.2.5-cp37-cp37m-win_amd64.whl
Installing lxml-4.2.5-cp37-cp37m-win_amd64.whl to c:\users\julia\appdata\local\programs\python\python37\lib\site-packages
writing requirements to c:\users\julia\appdata\local\programs\python\python37\lib\site-packages\lxml-4.2.5-py3.7-win-amd64.egg\EGG-INFO\requires.txt
Adding lxml 4.2.5 to easy-install.pth fileInstalled c:\users\julia\appdata\local\programs\python\python37\lib\site-packages\lxml-4.2.5-py3.7-win-amd64.egg
Searching for future>=0.15.0
Reading Links for future
Downloading https://files.pythonhosted.org/packages/00/2b/8d082ddfed935f3608cc61140df6dcbf0edea1bc3ab52fb6c29ae3e81e85/future-0.16.0.tar.gz#sha256=e39ced1ab767b5936646cedba8bcce582398233d6a627067d4c6a454c90cfedb
Best match: future 0.16.0
Processing future-0.16.0.tar.gz
Writing C:\Users\Julia\AppData\Local\Temp\easy_install-gclzxmnt\future-0.16.0\setup.cfg
Running future-0.16.0\setup.py -q bdist_egg --dist-dir C:\Users\Julia\AppData\Local\Temp\easy_install-gclzxmnt\future-0.16.0\egg-dist-tmp-wif7ukkz
warning: no files found matching ‘.au’ under directory ‘tests’
warning: no files found matching '.gif’ under directory ‘tests’
warning: no files found matching ‘*.txt’ under directory ‘tests’
future.backports.test.pycache.ssl_servers.cpython-37: module references file
future.backports.test.pycache.support.cpython-37: module references file
future.standard_library.pycache.init.cpython-37: module references file
future.standard_library.pycache.init.cpython-37: module references path
future.utils.pycache.init.cpython-37: module MAY be using inspect.stack
past.builtins.pycache.misc.cpython-37: module MAY be using inspect.stack
past.translation.pycache.init.cpython-37: module references file
past.translation.pycache.init.cpython-37: module references path
creating c:\users\julia\appdata\local\programs\python\python37\lib\site-packages\future-0.16.0-py3.7.egg
Extracting future-0.16.0-py3.7.egg to c:\users\julia\appdata\local\programs\python\python37\lib\site-packages
Adding future 0.16.0 to easy-install.pth file
Installing futurize-script.py script to c:\users\julia\appdata\local\programs\python\python37\Scripts
Installing futurize.exe script to c:\users\julia\appdata\local\programs\python\python37\Scripts
Installing pasteurize-script.py script to c:\users\julia\appdata\local\programs\python\python37\Scripts
Installing pasteurize.exe script to c:\users\julia\appdata\local\programs\python\python37\ScriptsInstalled c:\users\julia\appdata\local\programs\python\python37\lib\site-packages\future-0.16.0-py3.7.egg
Searching for XlsxWriter>=0.7.3
Reading Links for xlsxwriter
Downloading https://files.pythonhosted.org/packages/3d/1b/4caecd4efde1d41ba3bef1a81027032a7a6dff7d5112e1731f232c0addb9/XlsxWriter-1.1.2-py2.py3-none-any.whl#sha256=7cc07619760641b67112dbe0df938399d4d915d9b9924bb58eb5c17384d29cc6
Best match: XlsxWriter 1.1.2
Processing XlsxWriter-1.1.2-py2.py3-none-any.whl
Installing XlsxWriter-1.1.2-py2.py3-none-any.whl to c:\users\julia\appdata\local\programs\python\python37\lib\site-packages
Adding XlsxWriter 1.1.2 to easy-install.pth file
Installing vba_extract.py script to c:\users\julia\appdata\local\programs\python\python37\ScriptsInstalled c:\users\julia\appdata\local\programs\python\python37\lib\site-packages\xlsxwriter-1.1.2-py3.7.egg
Searching for beautifulsoup4>=4.3.2
Reading Links for beautifulsoup4
Downloading https://files.pythonhosted.org/packages/21/0a/47fdf541c97fd9b6a610cb5fd518175308a7cc60569962e776ac52420387/beautifulsoup4-4.6.3-py3-none-any.whl#sha256=194ec62a25438adcb3fdb06378b26559eda1ea8a747367d34c33cef9c7f48d57
Best match: beautifulsoup4 4.6.3
Processing beautifulsoup4-4.6.3-py3-none-any.whl
Installing beautifulsoup4-4.6.3-py3-none-any.whl to c:\users\julia\appdata\local\programs\python\python37\lib\site-packages
writing requirements to c:\users\julia\appdata\local\programs\python\python37\lib\site-packages\beautifulsoup4-4.6.3-py3.7.egg\EGG-INFO\requires.txt
Adding beautifulsoup4 4.6.3 to easy-install.pth fileInstalled c:\users\julia\appdata\local\programs\python\python37\lib\site-packages\beautifulsoup4-4.6.3-py3.7.egg
Searching for pytz>=0a
Reading Links for pytz
Downloading https://files.pythonhosted.org/packages/52/8b/876c5745f617630be90cfb8fafe363c6d7204b176dc707d1805d1e9a0a35/pytz-2018.6-py2.py3-none-any.whl#sha256=91e3ccf2c344ffaa6defba1ce7f38f97026943f675b7703f44789768e4cb0ece
Best match: pytz 2018.6
Processing pytz-2018.6-py2.py3-none-any.whl
Installing pytz-2018.6-py2.py3-none-any.whl to c:\users\julia\appdata\local\programs\python\python37\lib\site-packages
Adding pytz 2018.6 to easy-install.pth fileInstalled c:\users\julia\appdata\local\programs\python\python37\lib\site-packages\pytz-2018.6-py3.7.egg
Searching for urllib3<1.25,>=1.21.1
Reading Links for urllib3
Downloading https://files.pythonhosted.org/packages/8c/4b/5cbc4cb46095f369117dcb751821e1bef9dd86a07c968d8757e9204c324c/urllib3-1.24-py2.py3-none-any.whl#sha256=8819bba37a02d143296a4d032373c4dd4aca11f6d4c9973335ca75f9c8475f59
Best match: urllib3 1.24
Processing urllib3-1.24-py2.py3-none-any.whl
Installing urllib3-1.24-py2.py3-none-any.whl to c:\users\julia\appdata\local\programs\python\python37\lib\site-packages
writing requirements to c:\users\julia\appdata\local\programs\python\python37\lib\site-packages\urllib3-1.24-py3.7.egg\EGG-INFO\requires.txt
Adding urllib3 1.24 to easy-install.pth fileInstalled c:\users\julia\appdata\local\programs\python\python37\lib\site-packages\urllib3-1.24-py3.7.egg
Searching for idna<2.8,>=2.5
Reading Links for idna
Downloading https://files.pythonhosted.org/packages/4b/2a/0276479a4b3caeb8a8c1af2f8e4355746a97fab05a372e4a2c6a6b876165/idna-2.7-py2.py3-none-any.whl#sha256=156a6814fb5ac1fc6850fb002e0852d56c0c8d2531923a51032d1b70760e186e
Best match: idna 2.7
Processing idna-2.7-py2.py3-none-any.whl
Installing idna-2.7-py2.py3-none-any.whl to c:\users\julia\appdata\local\programs\python\python37\lib\site-packages
Adding idna 2.7 to easy-install.pth fileInstalled c:\users\julia\appdata\local\programs\python\python37\lib\site-packages\idna-2.7-py3.7.egg
Searching for chardet<3.1.0,>=3.0.2
Reading Links for chardet
Downloading https://files.pythonhosted.org/packages/bc/a9/01ffebfb562e4274b6487b4bb1ddec7ca55ec7510b22e4c51f14098443b8/chardet-3.0.4-py2.py3-none-any.whl#sha256=fc323ffcaeaed0e0a02bf4d117757b98aed530d9ed4531e3e15460124c106691
Best match: chardet 3.0.4
Processing chardet-3.0.4-py2.py3-none-any.whl
Installing chardet-3.0.4-py2.py3-none-any.whl to c:\users\julia\appdata\local\programs\python\python37\lib\site-packages
Adding chardet 3.0.4 to easy-install.pth file
Installing chardetect-script.py script to c:\users\julia\appdata\local\programs\python\python37\Scripts
Installing chardetect.exe script to c:\users\julia\appdata\local\programs\python\python37\ScriptsInstalled c:\users\julia\appdata\local\programs\python\python37\lib\site-packages\chardet-3.0.4-py3.7.egg
Searching for certifi>=2017.4.17
Reading Links for certifi
Downloading https://files.pythonhosted.org/packages/56/9d/1d02dd80bc4cd955f98980f28c5ee2200e1209292d5f9e9cc8d030d18655/certifi-2018.10.15-py2.py3-none-any.whl#sha256=339dc09518b07e2fa7eda5450740925974815557727d6bd35d319c1524a04a4c
Best match: certifi 2018.10.15
Processing certifi-2018.10.15-py2.py3-none-any.whl
Installing certifi-2018.10.15-py2.py3-none-any.whl to c:\users\julia\appdata\local\programs\python\python37\lib\site-packages
Adding certifi 2018.10.15 to easy-install.pth fileInstalled c:\users\julia\appdata\local\programs\python\python37\lib\site-packages\certifi-2018.10.15-py3.7.egg
Finished processing dependencies for kicostC:\Users\Julia>
I decided to give the GUI a try, since I much prefer a GUI. I was told I was missing some dependencies so I followed the instructions to add them:
C:\Users\Julia>kicost
You don’t have the wxPython dependence to run the GUI interface. Run once of the follow commands in terminal to install them:
pip3 install -U wxPython # For Windows & macOS
pip install -U -f Index of /wxPython4/extras/linux/gtk3/ubuntu-16.04 wxPython # For Linux 16.04
Or download from last version from https://wxpython.org/pages/downloads/
C:\Users\Julia>pip install -U wxPython
Collecting wxPython
Downloading https://files.pythonhosted.org/packages/34/41/e0e109a72966f596a5b93123d94eaabd53509ef6766fa3321b4bfadbbb14/wxPython-4.0.3-cp37-cp37m-win_amd64.whl (22.7MB)
100% |████████████████████████████████| 22.7MB 1.3MB/s
Collecting PyPubSub (from wxPython)
Downloading https://files.pythonhosted.org/packages/ab/9e/3b50915d3346971aaa49074425788598ee4907e67c097e013f1a862bd45c/Pypubsub-4.0.0-py3-none-any.whl (63kB)
100% |████████████████████████████████| 71kB 3.4MB/s
Collecting six (from wxPython)
Downloading https://files.pythonhosted.org/packages/67/4b/141a581104b1f6397bfa78ac9d43d8ad29a7ca43ea90a2d863fe3056e86a/six-1.11.0-py2.py3-none-any.whl
Installing collected packages: PyPubSub, six, wxPython
The scripts helpviewer.exe, img2png.exe, img2py.exe, img2xpm.exe, pycrust.exe, pyshell.exe, pyslices.exe, pyslicesshell.exe, pywxrc.exe, wxdemo.exe, wxdocs.exe and wxget.exe are installed in ‘c:\users\julia\appdata\local\programs\python\python37\Scripts’ which is not on PATH.
Consider adding this directory to PATH or, if you prefer to suppress this warning, use --no-warn-script-location.
Successfully installed PyPubSub-4.0.0 six-1.11.0 wxPython-4.0.3
The stuff at the end about things missing from PATH sounds interesting, but unfortunately I have no idea how to “add this directory to PATH”. So after this possibly successful (but maybe not) install, I try to launch the GUI again:
Traceback (most recent call last):
File “C:\Users\Julia\AppData\Local\Programs\Python\Python37\Scripts\kicost-script.py”, line 11, in
load_entry_point(‘kicost==1.0.3’, ‘console_scripts’, ‘kicost’)()
File “c:\users\julia\appdata\local\programs\python\python37\lib\site-packages\kicost-1.0.3-py3.7.egg\kicost_main_.py”, line 215, in main
kicost_gui() # Use the user guide if no input is given.
File “c:\users\julia\appdata\local\programs\python\python37\lib\site-packages\kicost-1.0.3-py3.7.egg\kicost\kicost_gui.py”, line 995, in kicost_gui
frame = formKiCost(None)
File “c:\users\julia\appdata\local\programs\python\python37\lib\site-packages\kicost-1.0.3-py3.7.egg\kicost\kicost_gui.py”, line 493, in init
self.set_properties()
File “c:\users\julia\appdata\local\programs\python\python37\lib\site-packages\kicost-1.0.3-py3.7.egg\kicost\kicost_gui.py”, line 805, in set_properties
s=numbers.get_currency_symbol(currency),
File “c:\users\julia\appdata\local\programs\python\python37\lib\site-packages\babel-2.6.0-py3.7.egg\babel\numbers.py”, line 143, in get_currency_symbol
return Locale.parse(locale).currency_symbols.get(currency, currency)
AttributeError: ‘NoneType’ object has no attribute ‘currency_symbols’
No idea what went wrong. OK, let’s try without the GUI just to see if I can get it to do something. The usage example given in the docs
kicost -i schem.xml
is obviously not going to work for me as-is, since my xml is on a network volume. So I take a stab at specifying the path in the invocation:
kicost -i X:\Projects\My Customer\A Great Project\Circuitry\schema.xml
But apparently it’s still 1979 somewhere in the world, where spaces are mysterious, dangerous, impossible-to-parse characters that must not be allowed in paths. Alright, move the file to a local path that doesn’t contain spaces, and
C:\Users\Julia>kicost -i C:\Users\Julia\Documents\Projects\MyCustomer\MyProject\schem.xml
Progress: 0%| | 0/81 [00:00<?, ?part/s]Traceback (most recent call last):
File “c:\users\julia\appdata\local\programs\python\python37\lib\site-packages\kicost-1.0.3-py3.7.egg\kicost_main_.py”, line 257, in main
dist_list=dist_list, currency=args.currency)
File “c:\users\julia\appdata\local\programs\python\python37\lib\site-packages\kicost-1.0.3-py3.7.egg\kicost\kicost.py”, line 192, in kicost
dist_octopart.query_part_info(parts, distributor_dict, currency)
File “c:\users\julia\appdata\local\programs\python\python37\lib\site-packages\kicost-1.0.3-py3.7.egg\kicost\distributors\dist_octopart.py”, line 364, in query_part_info
get_part_info(octopart_query, parts)
File “c:\users\julia\appdata\local\programs\python\python37\lib\site-packages\kicost-1.0.3-py3.7.egg\kicost\distributors\dist_octopart.py”, line 257, in get_part_info
for result in results:
TypeError: ‘NoneType’ object is not iterable
So I’m stuck at this point and would appreciate any help, thanks!
