Cannot delete BMP image on PCB or get it to render in 3D view
I am using the latest version of KiCad v7.0.10 on the latest version of Arch Linux v6.7.0-arch3-1.
Everything is up to date with the latest software versions.
On the PCB I have
  • clicked to select the F.Silkscreen layer
  • clicked “Place” on the main menu then “add bitmap image”.
I then resized my bitmap image by clicking on the corner of it and dragging the corner to get the desired size, then I dragged the image to the correct placement on the board.
Since then I decided to delete the image. But although I can see it, I cannot find it on any of the layers and it is unselectable for deleting.
The image does not show on the 3D model when I press alt+3.
How can I delete this image so I can replace it with another, and make it viewable on the 3D model.
not able to select the image: PCB Layout Place Image behavior - v7.0.0 vs 7.0.10
Thank you. This appears to be a bug according to the post you have linked.
I will have a go at downgrading KiCAD when I get a moment.
Instead of downgrading you could also use one of the testing builds Piotr has mentioned in his last answer. Albeit I don’t know if testing builds are available (and where to download) for your OS.
7.0.11 has already been tagged as rc1.2, so I expect what might be the last V7 version fairly soon.
Once V8 is released, V7 will freeze unless something very serious gets found
edit
rc2 became rc1.2
I needed to use graphics and downloaded a nightly version - works…
I use a Mac - this is the version I downloaded two days ago:
For anyone on Arch Linux, the below steps to downgrade the KiCAD package should resolve the image deletion issue but not allow you to see it in 3D.
I have successfully used downgraded package version 7.0.9-2 to delete the image on the board with these steps
  1. the Arch package cache, all packages, are here Index of /packages/k/kicad/**
    Choose the downgraded package you want.
REPLACE XXX below with the above link.
  1. Download the package and the signature file as follows:
sudo wget -P /var/cache/pacman/pkg/ -c --retry-connrefused --tries=0 --timeout=5 XXX/kicad-7.0.9-2-x86_64.pkg.tar.zst.sig
  1. Arch downgrade package command. This simply removes any newer package and installs the package specified
sudo pacman -U /var/cache/pacman/pkg/kicad-7.0.9-2-x86_64.pkg.tar.zst
  1. Delete any conflicting files
“error: failed to commit transaction (conflicting files)
kicad: /usr/share/locale/pt_br/LC_MESSAGES/kicad.mo exists in filesystem”
sudo rm -rf /usr/share/locale/pt_br/LC_MESSAGES/kicad.mo
Use downgrade package command again.
Now image deletion is possible.
After installing downgraded package 7.0.9-2 I can now delete the image but not see the image before I delete it in the 3D viewer using alt+3.
Are there any specific settings I have to change to be able to see this image which is on layer F.Silkscreen
Does the image have to be eg a particular colour, or inserted a specific way.
Your placed image is named “reference image” in the “Place” menu. Such a reference image is not supposed to shine up in 3D or any other output file.
If you want to include a graphic on the silkscreen (or any other layer) you should use File–>Import–>graphics. This accepts vector files (format dxf/svg).
Thank you. With both the latest KiCAD v7.0.10 and v7.0.9-2 I can’t see any menu item named
reference image” in the “Place” menu after
  • inserting an image
  • or importing a SVG.
The good news is that by converting my bitmap image to SVG in Inkscape, I am then able to import the SVG to the silkscreen layer, see it there, move it around and if need be delete it, and see this in the 3D model.
Thanks a lot
It works okay in 7.0.11 rc1
(note: not all of my SVG’s are importable but, it’s not Kicad’s fault).
Try Plotting an SVG from Kicad then, try Importing it…
Thanks BlackCoffee, I’ve got that.
Appreciate the help on here. It’s really helped me out.
Thanks all :pray:
