What will happen if you put a constant voltage onto an inductor, which does not have any series resistance? Did you measure the current?
What will happen when adding a resistor into the circuit loop?
Spice does not accept 0 Ohm resistors, as this would result in an infinite conductance in its circuit matrix. in ngspice they are replaced by a 1m Ohm resistor.
If I short R1, it come back to the same simulation result as the version do not have R1.
The reason I put R1 there is trying to be the source resistance of the V1, and try to see the impedance ratio of R3 convert back to the prime side.
@holger Thank you for the help.
I checked the current and believe that is the problem as the current all going really high.
If I add a 1 ohm series resistor to the inductor, it start to make some sense.
But the the question come is how should I simulate a differential 100 ohm trace on PCB at the DAC output?
I tried a simple VSIN followed by a TLINE, and configure the TLINE to 100 ohm, 1ns as the following:
KiCad should not crash, even with wrong input.
Ground connections are missing. Spice always needs at least one GND, here two (on both sides of the TM).
A delay of 1ns is absolutely not visible with a 1kHz input frequency, but will lead to 10m/1n=10Million data points, a little too much.
Please run the attached file with a somewhat corrected circuit and tell me which ngspice version you have. tm.7z (4.6 KB)
You might raise the frequency (a DAC output is 100MHz, not 1kHz), and use a pulse input. Then a 1ns delay becomes reasonable.
