Backspace, arrow keys desn't wok - renew
I have same symthoms like described in Backspace,left,right keys not working (topic is jus closed).
None of mentioned methods not help for me.
I use Ubuntu 18.04 LTS with KDE Plasma installed.
I have additional observation:
Backspace and arrow keys not working:
  1. Always on my account independent which window manager I use: (Plasma/LXDE/gnome/xfce)
  2. Only on my account other account (root & other non-root users everything works fine)
So looks like issue is somewhere in user account settigs for some specific component
I removed ~…config/kicad ~/.config/gtk3 but it doesn’t help.
I changes owner/group for me on all folders/files in my home directory but is still the same… :frowning:
On all other accounts kicad all keys work fine except my own.
Have you got any suggestion?
Regards,
Robert
Please your version info from kicad.
Hello:
Here if Kicad version info:
Application: KiCad
Version: 5.1.9-73d0e3b20d~88~ubuntu18.04.1, release build
wxWidgets 3.0.4
libcurl/7.58.0 OpenSSL/1.1.1 zlib/1.2.11 libidn2/2.0.4 libpsl/0.19.1 (+libidn2/2.0.4) nghttp2/1.30.0 librtmp/2.3
Platform: Linux 4.15.0-112-generic x86_64, 64 bit, Little endian, wxGTK
wxWidgets: 3.0.4 (wchar_t,wx containers,compatible with 2.8) GTK+ 3.22
Boost: 1.65.1
Curl: 7.58.0
Compiler: GCC 7.5.0 with C++ ABI 1011
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=ON
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_PYTHON3=ON
KICAD_SCRIPTING_WXPYTHON=ON
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
One remark if I login locally to linux desktop PC where this app is installed using lxde problem is visble
backspaca and arrow keys doesn’t work. When I start app in remote session via xrdp mentioned keys work correclty. Probably in case of xrdp owner of some X-subsystem is different.
Another remark if I login locally (so when problem occurs) and use (press) arrow keys few times application froze then crash.
Is possible to take any logs?
Regards,
Robert
