SnowMB
January 31, 2018, 7:05pm
#1
after installing package updates as usual, KiCad got completely unusable. Didn’t render UI Buttons in Cvpcb and PCB Layout and eventually completely crashed.
By looking into my update history I could resolve this issue by reverting wxpython to 3.0.2.0-6.
Tried the following nightly builds:
kicad-git-r9079.bf44d394c
kicad-git-r9260.c95c77c51
kicad-git-r9338.c758e72c1
Do someone know if this issue is already taken care of?
I assume you already know this, but the right place to report is the bugtracker not the user forum:
As this is a user forum, the users here can only try to offer a workaround for your problem not a fix. This means there might be a reason to post here but make it clear that you ask for help fixing your problem via a workaround.
Bug in the software
To help the kicad development effort it is suggested to post your bug description over at the bugtracker .
A detailed explanation on how this is done can be found in the report a bug section of the KiCad website.
Another detailed description about h…
When using wxpython 3.0.2.0-7, which is default repos for arch-linux and derivatives. All the menus in kicad does not render, and the software will not shut down, instead hangs in a infinite loop.
I will put this here and maybe make some further...
I reported a bug here, please help with adding info about findings or preferably even patches for this.
c4757p
February 2, 2018, 11:02pm
#4
This is an Arch Linux issue, they changed the wxpython
package from gtk2 to gtk3. Install wxpython-gtk2
from AUR instead.
system
Closed
March 5, 2018, 5:25pm
#6
