Apologies from atommann (an engineer from JLCPCB), about Gerber X2 files at JLCPCB
Hi all,
I joined JLCPCB as a technical support engineer for overseas customers in about October 2020.
Recently I noticed some customers received defective PCBs, issues are:
  • Traces are completely missing for some designs.
  • Rectangle pads with round corners are deformed.
  • Silkscreen layers are completely lost for some designs.
  • Some pads’ soldermask were lost.
I checked the Gerbers and see lots of them are in Gerber X2 format from KiCad. The issues are related to the work flow at JLCPCB, more details please move to: JLCPCB - strange issue with rounded rectangle pads + kicad nightly
Yesterday I discussed this with the head from the prototype manufacturing department. So we agreed to a decision: If CAM-A (the main CAM software used) can not import the user’s Gerbers and if it’s from KiCad and it’s Gerber X2. We need to ask the customer to re-plot the Gerbers in RS-274X format.
This morning, when I reached the office. I see tons of orders are in Gerber X2 format and they are stopped! I wrote an email template, so my colleagues can send it to customers to inform them to re-plot the file in RS-274X format.
I feel nervous as lots of orders will be delayed and maybe my method is overkill.
So I write this letter here to apologize for all the inconvenience.
By the way, JLCPCB is working on to support Gerber X2. We’ll announce it when it’s ready.
Best regards,
Atommann
Thank you very much. Can you still clarify, which options must be checked and which unchecked? There were two involved.
Below is a link to a wishlist item to be able to import and export settings for gerber files.
When this gets implemented, PCB manufacturers can make a file with settings available that works best with their manufacturing process.
I also had a look at the JLC website, and there already is a page (with screenshots) for Gerber settings for KiCad V5.1.5 for their process:
[Edit] Updating that website with similar instructions for KiCad V5.99 (soon to become KiCad V6) would help in the meantime.
This is a similar page for KiCad V4 (according to the last screenshot), but the text does not mark it as such.
@paulvdh, that is not accurate! We are talking about v5.99 which is different. It generates different kind of gerbers. Linking to 5.1 instructions doesn’t help, it may create more confusion.
Yes, v5.99 has lots of problems at JLCPCB now. I just checked a quality issue complaint: The design is an open source keyboard I guess. It has nice artwork (big logo, with complicated shapes) on bottom silkscreen layer, but the physical PCB does not have it! When the engineer imported it into CAM-B, the bottom silkscreen was gone but top silkscreen was keeped.
%TF.GenerationSoftware,KiCad,Pcbnew,(5.99.0-6667-gfc6fc88219)*%
This is what is confusing… GerberX2 is backwards compatible and thus the only way GerberX2 is being mangled (but GERBER isn’t) is aspects of the underlying GERBER parser is incomplete and thus is not to specification. Possible case of “good enough”
eelik mentioned this thread in:
but not the other way around.
As I read it, this (newer) feature in the use of Gerber in KiCad is incompatible with the (older?) implementation that is used by JLCpcb.
Did a quick test. manila-ice is used in this test, thanks Joshua.
X2 = No and Macros = Yes
The settings:
  • Uncheck “Use extended X2 format (recommended)”, i.e. X2 is disabled.
  • Uncheck “Disable aperture macros (non recommended)”, i.e. Aperture Macros are enabled.
CAM-A
CAM-A reads KiCad’s Aperture Macro RoundRect correctly, we can see the structure clearly.
CAM-B
(Some specific version of it)
We can see the round corners are missing in CAM-B.
X2 = No and Macros = No
The settings:
  • Check “Disable aperture macros (non recommended)”, i.e. Aperture Macros are disabled.
CAM-A
CAM-A reads it correctly.
CAM-B
(some specific version of it)
CAM-B reads it correctly too.
Answered, see the screenshot in my last post.
Yes, that confirms what I understood after all related discussions: Disable (uncheck) X2, Disable (check) the new aperture macros.
The working solution for 5.99 until JLCPCB gerber processing is changed
So essentially don’t do the recommended stuff. Weird. :man_shrugging:
Thanks for clarifying this to us @eelik
A slightly tangential but related question.
Is it possible or are there plans to have presets for Fabrication Outputs ?
It’s these sort of Board House idiosyncrasies that get forgotten if you use different companies to manufacture different PCBs. I would certainly find it useful to save a preset for JLCPCB, PCBWay etc etc etc
From the “wishlist” item on github I linked earlier to in this thread:
Such a CAM dialog could then also handle exporting and importing CAM
settings.
So KiCad developers are aware of the idea, but currently it is not implemented yet. If you like it, then give it a thumbs up on gitlab. (Current count is 11).
Hah! I’m not awake yet am I. I’ll try and read rather than scan next time !
I certainly will give it a thumbs up, thanks.
In most areas KiCad tries to be conservative, and not make changes that might cause bad PCBs. So I am puzzled why KiCad pushes Gerber X2 so much, it is just one proprietary standard after all.
Because X2 is good (X3 is better) in that it completes the fabrication info (and then assembly info) AND it works. If a fab house accepts GERBER they will work with GERBER-X2
If you look at the test it would appear the issue is with appature and not X2 ( in as far as an exhaustive combination test was not performed). This makes more sense as X2 adds info to COMMENTS and thus is ignored by older parsers
If X2 fails then there is a flaw in X1 readers as it is non-compliant
Other more open standards perform the same function, and it is clear X2 DOES NOT always work.
I don’t understand why we are pushed to join the “crusade to get everyone X2 compliant”.
I just want to make cheap PCBs. Please don’t make me join your religion.
It seems there are issues with using X2 even without aperture macros - see my post here: JLCPCB - strange issue with rounded rectangle pads + kicad nightly - #6 by DavidR
I do agree though that in principle it should be fine for KiCad to default to using Gerber X2 because of the backwards compatible design. And as @atommann said, JLCPCB are working on a preprocessing script to strip out the X2 stuff which shouldn’t be too difficult to do.
On the other hand, I think the move towards using aperture macros is a bit more questionable. There was nothing wrong with the old approach, and it seems that multiple pieces of software struggle to implement aperture macros correctly (see Gerber Aperture Macros are hard for everyone | Horizon EDA Blog ). So, I think it may be wise to have aperture macros off by default.
Like what? IPC-2581 no one uses it and Kicad doesn’t support it. ODB++ quite a few places support it but Kicad doesn’t. RS-274D the defacto standard, yes but things have moved on and here is the kicker… RS-274X is an EXTENSION to RS-274D via adding additional infomation to GERBER comment sections
IF a CAM package or GERBER viewer fails to render a GERBER-X2 file then it is non-compliant to the original RS-274D specification and thus raises the question… what else is it not compliant to.
simply put I fail to see why I should trust something that is not compliant to the RS-274D specification with anything.
