My last project used a cheap chinese PCB house and I had to modify my PCB export settings to work with their outdated and buggy software (CAM 350).
Those settings are:
YES Use Protel filename extensions
YES Coordinate format: 4.5, unit mm
NO Use extended X2 format (recommended)
YES include netlist attributes
YES disable aperture macros (not recommended)
Can I just use these settings going forward for all fabs, even fancyschmancy US based ones, etc? Is there anything actually being lost by disabling the recommended settings?
Is there an actual noticeable difference to the PCB if Aperture Macros are disabled? Or X2 format? Or 4.5 format instead of 4.6?
There has been previous discussion on this you can read for background:
My pragmatic take is, if your fab supports X2 then use it, otherwise don’t. Unfortunately this is not the one answer for all you want.
I think there are plugins that store settings for each fab so you only have to select the fab and then push one button to generate the gerbers. I don’t use one though.
I should add that Protel filenames are generally not an issue with most fabs. They seem to be able to work out which files are for which layers, whatever the names.
