AK8963C compass schematic
I don’t know what you were trying to achieve in your screenshot but you are editing the library instance in bold (ak8963c) and not the highlighted line. I would remove this and the other CAMERART_LIBS directories and just stick to the instance in your CAMERART library.
I think I also replied to you in another thread
about how to design symbols.
Unfortunately, this is exactly not how to draw a symbol - you have tried to follow the pinout exactly - even to the extent of casting it as a square box to match the package shape.
It will be fiddly to connect up and have crossing wires and no logical flow.
Make it a bigger, rectangular block with power at top, GND at bottom, and arrange your spi bus pins together to match your controller pinout. Your schematic will be much cleaner.
