A New Label on Schematic - Error in Simulation
KiCAD 8 user
After creating a simple schematic (a DC battery, a 1ohm resistor, and a 10u capacitor) and defining initial condition “.ic” to make sure that the capacitor is uncharged at the initial time and gradually charged, we created a new label (n1) by placing it on a wire connecting the capacitor to the main wire. However, while starting the simulation, the simulation does not recognize the label placed on the resistor-capacitor node (n1). what to adjust or how to modify the schematic so that the n1 label is recognized by the ngspice simulation?
Circuit Elements:
  1. Voltage Source (V1)
    • Connected between ground (GND) and node n1
    • Piecewise linear source: pwl(“0 0 1m 3.6”)
  2. Resistor (R1)
    • Resistance: 1 ohm
  3. Capacitor (C1)
    • Connected between node n1 and ground (GND)
    • Capacitance: 10 microfarads
Node Connections:
GND —±-- V1 —±-- R1 —±-- n1 —±-- C1 — GND
Simulation Commands:
.tran 0.1 1
.ic v(n1)=0
Welcome to the forum.
It is always a good idea to post the version of KiCad that you are using (Help->About->Copy version and paste it here)
I this case a screenshot would also make it easier for people that could help you to understand exactly what is the situation.
Hello, Thank you.
How to I include screenshots of my window here in the forum?
I don’t remember the ‘new user’ restrictions so I just promoted you to basic. I’m on Linux and use Spectacle for screen shots. It offers a ‘copy to clipboard’ function. I then just paste the screen shot.
Thank you for your assistance.
n1 is the same as ground. Maybe you can’t arbitrarily rename GND?
Well, you’ve created a short circuit. I’m not certain sinulation makes sense at all.
Thank you I changed it. It’s now giving different results. cheers.
Thank you I’m looking into it now.
