7.0.0-nightly plugin manager fails to download package
Hi all,
In the nightly builds, the plugin manager fails to download packages. Here is an example (I’ve experienced this with multiple packages):
It is not that the plugin fails, it is that it can’t even be downloaded. I’ve checked the URL, that is correct, so I suspect that the problem is in KiCAD itself. Is this a known issue?
Thanks!
Version: (7.0.0-rc1-253-g7844602210), release build
wxWidgets 3.2.1
FreeType 2.12.1
HarfBuzz 5.0.1
FontConfig 2.14.1
libcurl/7.86.0-DEV Schannel zlib/1.2.13
Platform: Windows 11 (build 22000), 64-bit edition, 64 bit, Little endian, wxMSW
Date: Jan 18 2023 06:49:17
wxWidgets: 3.2.1 (wchar_t,wx containers)
Boost: 1.80.0
OCC: 7.6.2
Curl: 7.86.0-DEV
ngspice: 38
Compiler: Visual C++ 1934 without C++ ABI
KICAD_SPICE=ON
Probably this again Plugin manager: issue downloading plugins - #17 by marekr
Your build version has curl 7.86 in it with the bug.
Still same here. Is there an estimate when that will be solved?
That’s right, I think this is the same issue. Thanks!
