I’ve just upgraded my 5.1.4 to 5.1.5, to notice that something weird happened to the Interactive router.
It normally kept my tracks limited to straight or 45deg, but now sometimes it routes tracks at weird angles.
There’s a general setting for this, but should only apply to Legacy mode.
Please see the above drawing, there’s jagged track running at weird angle where the endpoint was not on a grid. Previousy the router just extended the track using the 90/45 degree rule.
Anyone noticed such behavior?
Hi eelik, thanks for the link. Ineed seems to be the same issue. Must be some regression bug, as never noticed the problem in 5.1.4. So still I will have to wait for my “perfect kicad”
I have noticed yesterday (5.1.5) situation very close to this bug but my grid was not set very fine (it was 0.1mm) but the track I was connecting to was not in grid (I don’t know which way it have happened - I didn’t changed my grid during routing).
Here is the situation during routing:
I was not able to have this track left horizontal. The connection point could be a little higher or a little lower than other track ends.
I didn’t noticed that in 5.1.4
I had the same problem. I finally had a straight line. I think I started the vertical track from a point of the the horizontal one. It can also be done by editing the vertical track and adjusting its coordinates.
There’s a “Thumbs up” button below original issue. Btw, this “thumbs up” seems a “trademark” of today.
What does it mean for a bug report? “OK, Nice bug.” ?.. “I like this bug, too” ?..
But if that works for the majority, it’s OK for me to click strange icons. I can live with that.
BTW, I keep working with my projects and must admit that this new bug is very annoying, unfortunately… Fixing these jaggies requires some patience.
@Pedro seem very closely related. Some change to Interactive Router can bypass the “45/90 degree” rule. It’s related to keeping the segment endpoints strictly on the grid. If you’re slightly off-grid (e.g. routed some traces using finer grid) it will forcely connect the ends using a method that bypasses the “45/90d” rule.
