What is the difference (except the name and hotkey) between “Reset view” (hotkey R) and “Home view” (hotkey “Home”) in the KiCad 3D viewer?
They seem to me, to do the same thing; return the 3D view to the default position, rotation and zoom.
What am I missing?
What is the difference between them, that is the cause for two different seemingly identical commands?
On my Linux box [Home] does nothing in the 3D viewer while [R] shows the PCB straight from the top.
In Preferences / Hotkeys[Home] also does not have a key assignment for the 3D Viewer for me, which implies the “Common / Zoom to Objects” may be the active function for the 3D viewer.
Edit / Addition: Do note I may have fiddled a bit with some of the key assignments at some point, so I can’t guarantee the settings I have are the default.
On the system I specify in my first post - fedora Linux with 7.99 nightly - Home and R do the same thing. I have not, that I know of, changed any hotkeys. It is an upgrade, not a fresh install, of the nightly though. The fresh install was probably in the summer.
If the intention is to have two different keys do the same thing, I would prefer that the tooltip / description for one or both of them would state clearly that they are equivalent. It would preempt at least some degree of confusion.
