3D Part Viewer/Editor inside KiCAD not working
Just installed KiCAD version 6.0.0, using Windows 10.
In the layout portion of KiCAD, when I select “Properties” on a certain footprint, then select the TAB “3D Models”, in the preview window, all I see is the pads to the part and nothing else. Even though the footprint is properly linked to the 3D Model. My ALT 3, board 3D viewer works fine. It shows all the associated 3D Models on the footprints. I’ve installed multiple versions of KiCAD, and they all have this same error inside the 3D part viewer in the layout.
3DViewerImage
Any idea how to fix this?
Mike
Does this happen with all footprints or only some official KiCad footprints? See Why a footprint points to a 3D model but the model file doesn't exist?.
This happens on ALL footprints, regardless of TH or SMD. I know that the path is good, because the ALT3 works just fine and shows all the associated 3D models on each footprint.
Mike
OK, looking at your screenshot, it looks like buggy 3D rendering. There have been similar problems which may be caused by problems in 3D hw/drivers.
Here: 3D viewer problem without raytracing
Thanks to all who helped. It was a driver issue in Radeon Pro Setting graphics card.
Created a custom profile for KiCAD.exe.
That fixed it!!!
Mike
