It seems to me that the 74xGxx:74LVC1G3157 (analog spdt switch) has the logic reversed wrt the datasheet. The datasheet tells me that with select=0 (pin 6) it should connect pin 4 and pin 3. The symbol tells me select=0 will connect pin 4 and pin 1. Or am I reading the symbol wrong? (All the other 3157 in the Analog_Switch library seems to have this right.)
Looking at Nexperia and TI, S=0 selects pin3. Annoying one uses Y0 and Y1 and the other B1 and B2 - designed to confuse.
I agree, the symbol is wrong
