We have several times needed to implement a 2-pad component as a PCB trace. Use cases include:
- We need to separate the analog and digital grounds of a circuit that uses a microcontroller, and connect them together at just one point of our choice;
- We use fine PCB traces to implement a strain gauge;
- We want to implement a small inductor as a spiral of copper trace.
In all cases, we need the two ends of the component that is implemented as a PCB trace to be on different nets. Otherwise things can go badly wrong very quickly. We could achieve this by inserting a 0R resistor in series with the PCB trace concerned. But this is not optimal, and sometimes there is insufficient space for an additional component.
One option would be to create a mall 2-pad footprint in KiCad such that the 2 pads are shorted by a trace within the footprint, as long as Kicad treats the 2 pads as being on separate nets. Is this possible?
