How to specify the clearance from a zone fill to the board edge?
The setting Copper Zone Properties → Electrical Properties → Clearance has no effect on the edge clearance. File → Board Setup… →Design Rules → Contraints → Copper to edge clearance does in fact allow modifying the clearance. However, this prevents any components with pads to come closer to the board edge, which is not intended:
Version: 7.0.7+1, release build
That’s rather complicated, isn’t it? For an arbitrary edge? My PCBs aren’t rectangular or round. The image above was just an example from a simple test file, not the actual board. My boards have an arbitrary shape with milled cutouts (designed in a CAD program and imported as DXF).
# Beispiel für extra-clearance for all copper zones fills to Board edge.cuts
# wenn eine Zone anders als die anderen sein soll:
# (condition "A.Type =='Zone' && A.Name =='EXAMPLE_ZONE' "))
# for this check the ZONE musthave a name assigned (in zone properties dialog)
(version 1)
(rule "Clearance zone to board-edge"
(constraint edge_clearance (min 1.5mm))
(condition "A.Type =='Zone' "))
