Bonjour,
Comment fait-on pour avoir des zones hachurées sur un circuit imprimé pour signifier par exemple une zone haute tension (mon cas) sur le layer F.Silks par exemple?
Merci pour votre aide.
Try drawing a graphic polygon on the F.SilkS covering the whole zone.
A graphic polygon will be solid not hatched but is probably the simplest solution. If you need a true hatched are, you might need to import a graphic. In 5.99, you can create hatched copper zones, but there doesn’t appear to be an easy way to move the zone to a silk layer (apart from editing the file with a text editor).
Thanks for the answer, but the area created does not allow hatching (not found)
John_Pateman: Thanks also for the reply.
I don’t think the developers have done anything about this.
I used before “Eagle” since the very beginning that it existed (80’s) and it has always been implemented in this software.
I know you can import schemas from Eagle (I’ve done this before) so I’ll try to build in Eagle and import, but a lot of time is needed and I don’t have a lot of it.
I find it unfortunate that Kicad, who now has a good reputation, does not do this.
