I tried to connect all GND Copper Zone together but I am still getting this unconnected item in DRC check. Can somebody help me with what this error means and how can I solve this one?
It means one part of your front copper isn’t connected to the rest
Click the error and it will centre. Zoom out and see where the copper necked … Say due to vias
There is just a very small part of F.Cu visible, however, if you look at this detail:
You see that the two sections are not connected at the via.
Same on the other side:
So you have to move some via’s and find a balance so you have good connections both on the top and the bottom copper layers.
Thank you for pointing out the error. I moved via and adjusted the copper pour and it solved.
