Yet another Python teardrop script. Adds and deletes teardrops to a PCB. V0.3.3
Teardrops are a great idea, but I’ve found arc geometry teardrops give the best results, for clearance to nearby PADS, and allowing larger teardrops.
Not sure if you can support ARC as an option ?
its an issue for the manufacturer
if they feels it necessary they ask for permission to add it.
post-processing carried out at fab, as is balance patterns etc
IMHO
I am actually working on it right now. It is a bit complex but I think I will be able to get something quite quickly.
This is clearly possible. The only drawback is that it will generate complex zones for each teardrop. Nevertheless, can you (or anyone) give some references about the arc radius ? I am not able to find anything.
For sure, that’s why I want it !
have a look here …
and this is a function for annular checking
[quote=“Niluje, post:7, topic:3388”]
This is clearly possible. The only drawback is that it will generate complex zones for each teardrop. Nevertheless, can you (or anyone) give some references about the arc radius ? I am not able to find anything. [/quote]
This is how PADS layout sets ARC teardrops.
I think that ratio is a % of PAD diameter, and the teardrop polyline can match the trace width
You can see how much closer other pads/vias/corners can be placed, with curved teardrops.
It does not need a lot of segments to approximate the arc, maybe 5 or 7 a side ?
I wonder if KiCad scripts can trawl the DRC error reports/tags, as then a 2 pass could be possible, where offending teardrops are removed or adjusted.
PADS can also generate teardrops on angled entry into oval pads.
There are no teardrops on trace T junctions, they apply to “last-segment intersecting pad-outline”
I think there is arc support for tracks coming. Someone who does RF circuitry has got code working that does arc tracks… but I have no idea about how far away that is from implementation into the official branch.
@cbernardo, @keruseykaryu, @madworm or @caer will probably know more about the status - if there is any.
That’s the relevant thread:
Interesting, but that’s a ways-off, and a simple polyline segmented ARC approx will work now.
If course if full ARC entity support arrives, it will be easy to add.
Meanwhile, best to keep entities DRC and Shove understand,
Note that other CAD pgms have only modest ARC support, - for example, shove with ARC preserve is missing in Mentor.
Edit: I see road map info here, about DRC/ARC and complex Pad shapes
http://ci.kicad.org/job/kicad-doxygen/ws/Documentation/doxygen/html/v5_road_map.html
Hi @Niluje
any news from your side about the script?
thank you
Maurice
Hi @maui,
I have implemented all the requested features: (but the curved teardrops (but I am planning to code it soon)):
  • add teardrops only on selected via/pads if some are selected
  • add a method to fix the missing polygon parenthesis (this actually also solves the artefacts issue in GAL mode)
  • improve performances
  • Fixed some bugs in teardrops file
I only have to make it readable and clear before releasing it. This might be done by the end of the week.
It took me much more time than I initially though because I became father ten days ago which did not let me much brain time available.
I am now struggling with github to import my personal ssh-only hosted git repos. This will be much more efficient to share it here.
Hi @Niluje
CONGRATS!!! I can understand your happiness and brain storm!!!
I became father 2 years ago and I’m still feeling like that :smiley:
Maurice
@maui: Thank you very much! This is all new to me and I really enjoy it!
I managed to get the script done this evening. I created a github account for the occasion: https://github.com/NilujePerchut/kicad_scripts/tree/master and uploaded the script on it.
The readme gives some explanations about how to use the script.
I hope this will can be useful (and not too much buggy).
Thank for all the advices on this thread.
Next step: curved teardrops.
Sounds cool, looking forward to curved teardrops !
If the corrupted file error is solved, you could edit the thread title - maybe add a version number there ?
I expect this to be generally useful, and referred to often.
I have edited it to something more sensible
Congrats Maurice on the baby
Thanks for the modification, this looks better now.
As suggested by @PCB_Wiz, I also added the current revision and will keep it synced with the github version.
Curved teardrops are now available.
The script is still available on my github page:
The script behaviour is identical to the previous version (0.2.0).
Curved style is used by default. The number of segments per curved is controlled by the parameter “segs” of the setTearDrops function (default is 10).
If segs is set to 2, straight lines are used.
I hope this will help.
Notice: I am not very good in geometry and the only solution I found is to use a bezier curve in order to keep the teardrop tangent to the track and the via. It works but it is quite expensive in processing time. If someone has a better method, please let me know.
The script version is now 0.3.0 (the thread title is now modified)
HI
thankyou for your help, I get one error:
File “C:\Program Files\KiCad\lib\python2.7\site-packages\pcbnew.py”, line 31, in
import _pcbnew
ImportError: DLL load failed: %1 不是有效的 Win32 应用程序。
Win10 64bit
python2.7.4 64bit
@Niluje
The reason you’re getting corrupt output files is because you need to call z.CloseLastContour() after z.AppendCorner§
I see this as a bug in kicad; AppendCorner should call it for you. (I’ll suggest it on the developer maillist)
Sadly, the only way to know this is to step through the c code in the debugger.
Miles
I will correct it as soon as possible. This will be a huge enhancement!
I have filed a bug on this:
I probably should have done this when I first noticed the problem some weeks ago.
Thanks to your debug work, the non closing zone bug is now fixed.
I released a 0.3.1 version that does not require to patch the pcb file at all.
The scripts is updated on my github repo:
Thanks again !
