In PCBnew, suddenly all my pads and wires are kind of yellow/greenish instead of red , and when I select one, they get red (the entire connected lines).
Only some pads on the right (where there is no solder mask, the color is red).
I think I accidentally pressed a shortcut key that caused some visualization setting to be changed, but how to revert back?
(thanks for your help again) … I have all layers selected, I’m afraid all my wiring is now on the wrong layer (although near some vias the color is still red).
I know there’s a ‘flip’ key. That could have been it. Not sure exactly how to recover from that. I’ve only played with it a little. If you haven’t done a save just quit and come back? F as a matter of fact. Or UNDO works. Just tried that after flipping a zone.
I will check all settings … I already saved; I’m a software engineer, ctrl-s I do like breathing ;-). But it’s just some visualization setting, so I haven’t lost anything … I just cannot route anything now.
I found it … I must have pressed F9 (Legacy mode). That changes the colors; I’m not back on F11 (Modern Toolset, accelerated), and everything works again.
