I have a number of new PCBs that I have made and am testing now. A next step is coming up to speed on Fusion360. So far I have about 38 hours of “screen screaming” and 2 hours of actual work accomplished, but this is how coming up to speed with a new tool tends to go.
I’ve read a lot of threads, including:
“Library Management in KiCad Version 5” (am structuring things that way)
“How to share step 3D model with all the components on the PCB too?”
I have a lot of parts where I made the footprint (often a slight variation on the manufactures recommendation base on making small trial boards and reflowing parts onto the board). As such, I am looking for the 3D parts model. I am able to add in the 3D model for a given part for a given footprint using the footprint editor…
Here are my questions or assumptions that may need clarification:
I see both .stp/.step files and .wrl files as being supported in KiCad. Fusion360 seems to only like step files. Is KiCad inclined to perform better with one type vs. another ?
If I end up having to create 3D models in Fusion360, is that process units agnostic or should I always be in either imperial or metric units ?
Presumably the origin for any 3D model should be the center of the part, with pin 1 at the upper left so that things will align?
I was using the Library Loader with Mouser, but when I upgraded to the current version it has a 50-50 changes of working and crashes a lot. So now I’m thinking just find the 3D file and go with that. It seems the connector companies (CUI, Kycon, Keystone) do a better job of creating a 3D model than the chip manufactures. This is good becuase for the chassis, I am mainly concerned with getting the holes aligned with the connectors on the PCB. I don’t really care about the models being “artistic”/pretty, the main thing I’m looking for is when I export a 3D viewer board, I can then bring that into Fusion360 so I can create holes in the chassis that line up with connectors. Is this approach a good one ?
I have noticed that when I bring in a 3D model, such as a chip from TI, while the model looks OK and I can enter it as the model for a chip in the footprint editor, I can not see the model when I bring up the board in the 3D viewer. How to fix that ?
I’ve seen the StepUp software videos and discussions, but that seems very tied to the FreeCad program. Is there value to StepUp in my workflow with Fusion360 ?
I suspect a lot of the problems here come from having too many “standards” for 3D models. Then add in “best practices”/conventions for aligning/orienting 3D models to footprints. All my footprints are centered, pin 1 upper left. Is there a good solution for when the downloaded 3D models are aligned differently? I suspect I can bring them into Fusion360 and re-position them.
Enclosed is a picture of the 1st chassis I did as a learning curve for Fusion360. It’s a chassis for a PI 3 that can hold a 40mm fan. All the PCBs in this group are PI sized, it’s just a convenient size and I hope it makes the chassis design easier. This is a good example of what I’m trying to do with the PCBs I’ve made. Am working in KiCad V(5.1.5f)-3
The forums have great information but span a lot of time. I’m struggling with what the current state of the art is for all this.
TIA
