In posting an upload I noticed that one of my Silkscreen lines was not aligned with the ends of the other Silkscreen lines.
To fix this, currently in KiCad, the ends of each line needs to be properly placed to make an equal sided rectangle. This means, at the very least, moving the ends of just two(2) graphic elements. However, if in my case, there is also a need to move the lines, then that could be as many as eight(8) different graphical line end moves.
If the graphical element was already defined as a graphic rectangle then moving the edges on one side would also move the other graphical elements on the other side of the rectangle; just exactly the same way that current computer GUIees work.
Comments?
