function causes Kicad to crash. I can print OK but if I try to use
the File>Print>Print Prevue function the whole Kicad session crashes.
I don’t really know if this is a Windows 10 only issue as I did not
install Kicad until after my Win 10 upgrade.
My Windows Kicad version info is:
Version 4.0.0-rc1-stable, release build
wxWidgets 3.0.2 Unicode and Boost 1.57.0
Platform: Windows 8 (build 9200), 32 bit.
I wonder if anybody else has run into this issue?
I wonder if this might be solved when a Windows 10
Starting to sound like this bug only applies to Windows 32 bit but still not sure if it only applies to Windows 10. I wonder if anyone here can confirm that Eeschema>File>Print>Print Preview works OK under 32 bit Windows 7?
Yep, same issue I encountered, see here: Bug with new release?
4.0.0RC1 has a bug on the x32 build, building from source works fine, and the latest x32 build works fine, not sure when they fixed it, I did find out but forgot now, was a few weeks, possibly a month ago now. Of course, not sure when the next stable release candidate will be available, it should be fixed in that build, but until such time you will have to use a nightly build to do print preview.
